need help asap car running bad after manifold install?
Old Oct 16, 2009 | 06:56 AM
lalocivic's Avatar
Default need help asap car running bad after manifold install?
hey guys i have a d16z6 i just installed a skunk2 manifold and ever since that my car running real bad it keeps overheating and it smells bad from the exhaust it burning to much oil?and the idle stuters around 2000 rpms??what can it be at first the check engine came out but they told it might be because the sensors plugs arent right but i fix them and the check engine came off???what can it be guys cuz it was running normal with the stock one???plz hit me up
Old Oct 16, 2009 | 07:21 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: need help asap car running bad after manifold install?
Could be a lot of things.
Did you replace the manifold gasket? Are you sure you got all of the old gasket material off? Same with throttle body? And check the sensor plugs. If I remember right, MAP and TPS (maybe) have the same kind of plugs, and it's easy to accidentally flip them.
kevinrdz28
Apr 13, 2014 07:21 PM
frostt3ch
13
Apr 2, 2006 05:41 PM
Mattb16teg
Aug 9, 2005 06:51 PM
mookie
Aug 30, 2004 12:25 PM
boot machine 5000
Jun 17, 2002 02:30 PM
