Need second opinion on spark issue
Old Oct 15, 2009 | 05:11 PM
zx96_r's Avatar
New User
Default Need second opinion on spark issue
Hi guys,
I have a 1993 civic.
I believe i have this problem narrowed down to the coil but i would like some other opinions before i order this part.
Problem: Driving down the and car died. Power was still on but just died. Car would not start because i now have no spark from the distributer.
What i have Tested/Replaced: I replaced dist.cap and rotor. I tested the coil. Primary resistance is at 1.1 Ohms and secondary is at 13kOhm. For the icm i have 12 volts (when connected to coil) across the two wires that connect to the coil. With coil disconnected and light bulb in place of it, it turns off and on when i turn it over. This tells me that everything b4 the icm and output of icm is ok.
The recommended primary resistance is between .6 and .8 ohms were mine is 1.1 ohms. does this sound like a coil or icm problem?
Also could an icm ever "kind of " work? what i mean is could the icm be switching but not be outputting enough voltage to the coil?
Let me know if i was not descriptive enough.
Thanks for any help
Old Oct 15, 2009 | 10:23 PM
Scott_Tucker's Avatar
Default Re: Need second opinion on spark issue
I would suspect the ignition module before the coil. A light bulb simply does not have the proper impedance (internal resistance) and it cannot react fast enough to changing voltage to be a reliable test tool for this type of circuit. You need to use a logic probe, which is a high impedance test light that uses LED's instead of a bulb which uses a filament. They can flash really quickly.
Your coil resistance seems acceptable but I don't usually trust testing them with an ohm meter anyway since I've had bad coils that tested good on a resistance check.
Old Oct 16, 2009 | 10:01 PM
cr8ter's Avatar
just recently had a 94 accord at the shop for same thing....igniter was the problem...rarely does the coil go bad...
Old Oct 17, 2009 | 07:17 AM
4norzn's Avatar
any codes? i would say the igniter also
Old Oct 17, 2009 | 08:31 AM
fcm's Avatar
fcm
Old Fart
At this point I would also have to guess ICM. 94
bk7794
Nov 13, 2012 08:38 PM
ChilBlu92
Dec 28, 2006 06:35 PM
phildeez
Mar 15, 2002 07:22 PM
