EF Gas Mileage
Old Oct 15, 2009 | 12:44 PM
theguilbeaus's Avatar
Default EF Gas Mileage
So what are you getting??
I get 26-30. Its a Mix of city and highway.
I think It could be better. I just replaced spark plugs. but it hasnt changed much.
Old Oct 15, 2009 | 12:45 PM
kaiba's Avatar
Default Re: EF Gas Mileage
dx si hf
Old Oct 15, 2009 | 12:46 PM
BiG ChOr!Zo's Avatar
29 city
36 hwy
IBTL
Old Oct 15, 2009 | 12:47 PM
Originally Posted by kaiba
dx si hf
DX, 4sp
Old Oct 15, 2009 | 06:24 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Originally Posted by theguilbeaus
DX, 4sp
LOL @ YOU! You don't have an over-drive...
!!! IBTL !!!
Old Oct 20, 2009 | 02:41 PM
well on this tank i averaged out 30.12 mpg
tires at 35psi
Old Oct 20, 2009 | 03:02 PM
and my oxygen sensor isn't hooked up.
I have no idea where to connect it
Old Oct 20, 2009 | 04:04 PM
sde780's Avatar
It's screwed into the exhaust manifold on the passenger side of it.
I got 35 MPG in the city on a d15b2
Old Oct 20, 2009 | 04:39 PM
detuned's Avatar
d16a6 HF trans - 44mpg city, 54mpg highway
d16a6 DX trans - 40mpg city, 34mpg highway
****'s weaaaaak. IBTL!
Old Oct 20, 2009 | 05:37 PM
danetp's Avatar
53 hwy d16a6 si
Old Oct 20, 2009 | 05:48 PM
sde780's Avatar
Are you drafting behind trucks or what, I can't get past 38 on highway going 70 mph
Old Oct 21, 2009 | 04:42 AM
its screwed in the wire just isnt connected.
Old Oct 21, 2009 | 05:21 AM
~sp33~'s Avatar
EFB055
47mpg was the best i've ever gotten with my carb'ed ED.
Old Oct 21, 2009 | 05:22 AM
AlwaysDriven's Avatar
You all must drive like saints if you're getting that kind of mileage. I get between 26-30 like OP in a 90 std hatch.
Old Oct 21, 2009 | 05:23 AM
~sp33~'s Avatar
EFB055
Mine was a one off, i used to average low 30's.
Old Oct 21, 2009 | 05:24 AM
dephtone's Avatar
Hell I get between 40 and 45 with my b16 swapped EF hatch lol.
Got 50 MPG in my HF with Si trans in the city, on the highway it was worse haha.
Old Oct 21, 2009 | 07:05 AM
89LSED's Avatar
How the hell are you getting 50 With a B16/si?
I get 30 with a b18/Ls with 195/60's!!!
what is your secret, OH Great One?!?!
Old Oct 21, 2009 | 07:14 AM
CRXDrew's Avatar
27ish city, 37 highway.
b20vtec, Y1 trans w/ LSD (4.266 FD), 14" steelies, stock sized tires.
TUNED on eCtune. (I tuned in a large cruising sweet spot from 70-80 to get max gas mileage)
Old Oct 21, 2009 | 08:22 AM
guitarguru87's Avatar
I'm getting about 15 city and 23 highway. But I'm running with the check engine light on with codes 1/5/7. I haven't fixed it cuz I'm swapping soon :-).
Old Oct 21, 2009 | 11:04 PM
icanbrkurhrt's Avatar
got 17's on mine. i get like 22 city. is it just because of my rims or is there something else i should replace or clean. i get crappy mileage.
Old Oct 22, 2009 | 07:26 AM
89LSED's Avatar
17's on your... what? Details!
Old Oct 25, 2009 | 09:48 AM
Icon6 Re: EF Gas Mileage
alrighty so this week i got
31mpg
34mpg
and 30mpg
I fixed my idle problem with a easy 30min tops fix
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-clean-iacv-dpfi-idling-problem-2443124/
I was able to research this out on the forum and it is proven helpful!
when i took it apart I didnt find a wood chip but there was alot of dirt in it.
I just used carb cleaner to get it out, wear gloves it burns lol, highly recommend!!!!!!!!
and tires are still at 35psi.
Old Oct 25, 2009 | 09:53 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Quick review of MPG tips
1) New 02 Sensor
2) Cap, Rotor, Plugs, Wires
3) Tire Inflation
4) Motor and Trans oil
5) **New/rebuilt Distributor
6) Measure properly. Fill up at your favorite station, at your favorite PUMP. Zero out your trip odometer. Drive around. Go back to same station, SAME PUMP. Fill car. Note miles, and how much gas it took. Do math (Divide the two #s). Do same test 2 more times (same station, same pump, zero out each time).
** I've heard this, is this true?
Wheels and tires make a difference... weight, rolling resistance and all that.
Old Oct 25, 2009 | 09:55 AM
EL Vap133's Avatar
https://honda-tech.com/forums/showth...&highlight=MPG
Old Oct 25, 2009 | 09:56 AM
EL Vap133's Avatar
grg9988
Sep 18, 2007 03:48 PM
liquidoblivion
10
Jul 20, 2007 09:28 PM
stevescivic
27
Mar 8, 2007 08:20 PM
civicwagonman
Jul 20, 2006 02:08 PM
jdwebmaster
12
Aug 13, 2003 06:17 AM
