B20b head on b18a1?
Old Oct 15, 2009 | 12:34 PM
JDMPR's Avatar
Default B20b head on b18a1?
Thinking about buying a DB with a b20b head on the b18a1, is there an advantage to doing this? Basically I need to know if this setup will pass emissions.
Old Oct 15, 2009 | 02:10 PM
dmpd_ef's Avatar
Default Re: B20b head on b18a1?
i have heard that there is no worthwhile power to gain from this head swap.
as for emissions. i dont see why it shouldnt pass since the heads are very similar. GL
Old Oct 15, 2009 | 02:37 PM
JDMPR's Avatar
The kid says that the motor runs good, correct me if im wrong but the 91 is obd0 wouldnt the b20b head be obd1?
Old Oct 15, 2009 | 03:49 PM
EG6Boy702's Avatar
I never heard of that. That actually sounds kinda odd but why do you have to replace the head to pass emissions ?
Old Oct 15, 2009 | 03:56 PM
JDMPR's Avatar
I think what he did was peice together the motor and used a b20 head cause thats what he had, plus it has the newer b18b valve cover on it. But when you replace the head wouldnt you have to convert the obd? Cause I know when you put a b18b you have to convert the obd so it will run right
Old Oct 15, 2009 | 03:59 PM
EG6Boy702's Avatar
check the head stamps to see even what head you have on the car cuss if it has an ls valve cover odds are its an ls head. and have you even tried to pass emissions with it yet ?
Old Oct 15, 2009 | 04:10 PM
JDMPR's Avatar
No, where the kid lives they dont need to do inspection but since I live in the city I do. He says the car runs great, does it matter what obd it has? All they do here is smog test it
Old Oct 15, 2009 | 06:26 PM
EG6Boy702's Avatar
if all they do is a smog test they will just put a hose at the end of your exhaust to read how much o2 is coming out the exhaust so you should be fine
Johnoolo
Jul 7, 2013 01:34 PM
clockwork675
Jan 20, 2008 01:54 AM
lscrxhf
Apr 15, 2006 05:10 PM
Chuji
Sep 6, 2001 05:25 PM
