95 Civic EX coupe Part out + EDM rear fog FS
Old Oct 15, 2009 | 11:16 AM
accrdwgnguy's Avatar
Default 95 Civic EX coupe Part out + EDM rear fog FS
I have parted out a 1995 Civic EX 5 spd coupe recently, and for sale I have an EDM rear fog.
First up, the rear fog. It is very clean and I took it all apart to clean and polish all the parts. $110 gets it on your door step.
I also have a B18 valve cover removed from a DA Integra, stripped and painted with black wrinkle finish. Best offer gets it.
And last, a new EGR block plate from Honda. This will fit H22/H23/F22/F23 and K-series. Best offer
Ok on to the Civic partout!
I have an almost complete 5 spd swap parts set. I am missing the axles and throttle cable.
Shift linkage and shifter
Hydraulic lines and coupler
Master and slave cylinder
Pedals
OEM flywheel, if desired
Rear mount and bracket
Side frame mount and tranny mount, if desired
Starter
All associated hardware
Best offer, I will ship this stuff
Tilt column - $20
Black Civic steering wheel and airbag - $40
Its black, my flash just washed it out.
Coupe/Sedan OEM outer tail lights, in great shape. $15 each or both for $25
Passenger side headlight, good shape. $20
Ignition switch and complete lock set with one key. Should fit coupe, sedan and hatch. $40
Climate control - $20
Power window, lock, and mirror package for Coupes and Hatches - SOLD!
Cruise control actuator - $20 - I have not tested it as of yet.
OEM moldings - I have the coupe Quarter panel moldings in great shape, best offer takes them.
Black dash, shitty shape. $20
Passenger side airbag, black. $40
Civic Manual Trans radiator. $30 Good for Accord turbo builds, gives you more room for more turbo!
Condenser. $offer
Front EX sway bar and control arms.
Old Oct 15, 2009 | 03:54 PM
Skip01's Avatar
Default Re: 95 Civic EX coupe Part out + EDM rear fog FS
Dont have both the taillights..inner and outer?
Old Oct 15, 2009 | 04:02 PM
no sorry, just the outers
Old Oct 18, 2009 | 08:59 AM
ttt
Old Oct 19, 2009 | 04:27 PM
ttt
Old Oct 19, 2009 | 04:34 PM
95jdmej2's Avatar
Do you have the front sway bar with lower control arms?
Old Oct 19, 2009 | 04:37 PM
PM'd
Old Oct 21, 2009 | 07:16 AM
ttt
Old Oct 22, 2009 | 07:30 PM
Time to make requests for anything else, the shell is going to the crusher next week.
Old Oct 23, 2009 | 06:50 AM
HatchVX's Avatar
would you sell just the door latches by them self?
Old Oct 23, 2009 | 07:49 AM
Skip01's Avatar
Black carpet in good shape?
Rear speaker grills in black?
Old Oct 23, 2009 | 06:25 PM
95jdmej2's Avatar
just checking to see whats up with the front sway bar and control arms. You have got back with me and gave me a shipping quote. I gave u my email address, hit me up.
Old Oct 24, 2009 | 03:11 PM
Really want to sell the power setup as a package.
Rear speaker grills, yes. Black carpet, no
Pm'd
Old Nov 11, 2009 | 03:23 PM
ttt
Also have an antenna delete cap, brand new from Honda
Old Nov 11, 2009 | 04:15 PM
rob_the_rude's Avatar
New User
do you have passenger fender if yes what color
Old Nov 11, 2009 | 05:12 PM
Sorry no, its no good
Old Nov 12, 2009 | 03:25 AM
hi ho silver's Avatar
how much you want for the fender moldings? i think the only moldings that wont fit on the hatch are the rear quarter panel moldings right? otherwise i'd take it all
Old Nov 12, 2009 | 07:39 AM
Black-Ty [EG6]'s Avatar
bump
Old Nov 12, 2009 | 12:37 PM
wanderinglost's Avatar
Bump. Sent a PM about the power conversion stuff a while back, haven't heard from you yet. is it still available?
Old Nov 16, 2009 | 03:03 PM
ttt
Have a DA 40/40 prop valve
Old Dec 14, 2009 | 08:03 PM
bui1528's Avatar
pic of ignition assembly?
Old Dec 14, 2009 | 08:06 PM
Old Jan 8, 2010 | 10:52 AM
Lasky's Avatar
car still in your possession? i need the driver side spindle assembly as long as the wheel bearing is in good shape and no studs are broken or stripped - dont need rotor or caliper just upper control arm, hub, etc..
Old Jan 8, 2010 | 12:39 PM
sorry i traded those parts a long time ago
bump up everything cheap. Wanna get rid of all civic stuff!
Old Jan 27, 2010 | 07:41 PM
Up up
