obd0 - obd1 rywire conversion harness question
ODB0 to ODB1 conversion, motor is a z6 into an ef ( obviously
).. it says to connect the white wire to the knock sensor. z6 doesn't have a knock sensor so do i just connect this wire to the oil pressure switch above the oil filter or just leave it disconnected?
thanks in advance
).. it says to connect the white wire to the knock sensor. z6 doesn't have a knock sensor so do i just connect this wire to the oil pressure switch above the oil filter or just leave it disconnected?thanks in advance
yup leave it alone. the harnesses are made to fit dohc vtec applications which do use a knock sensor
Bsixteen_CRX
Jan 21, 2008 12:30 AM
ef8sleepr
14
Mar 3, 2006 11:38 PM
89dxhunchback
May 1, 2003 11:29 AM
