passing bar obd1 in a obd0 car ?
ok i have a 89 dx that i did a mpfi swap to then blew the motor then found a d15z1 for a go price and swaped it in... So my thing is im runing a p28 ecu and a jumper from obd0 to obd1 and im useing my stock si intake manfold AS WELL AS RUNING THE OBD1 O2 sensor and made a jumper for the dizzy ....now what is need to pass bar with a obd1 motor do i need to get the vx ecu and and not run the jumper or can i run the jumper and do i need to use the vx intake manfold or can i use my si or i was going to pick up a skunk2 manfold ? so can some one give me a link to what needs to be done or some thing thanks
Someone who is from your state will probably know your laws better but I'm shocked to hear you are tested on the motor's obd not the cars OEM one.
In my state I'm obd0 chassis (needless to say) with obd1 motor and wiring, I'm tested as an obd0 car.
You'll have to either search around or hopefully someone from your state can chime in.
Why do you need to bar your single cam motor?
You need to use everything that the VX came with from the factory.
ECU, intake manifold, intake air box, exhaust manifold... everything.
You can get away with using CARB legal replacement parts (AEM intake) made for the VX and jumper harnesses unless your ref is a jerk.
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
the smog ref isnt gonna care about the oem intake box, or the oem exhaust manifold he doesnt have time to track down what part number is on the box or manifold...... just make it look as stock as possible as for ecu he will check if you converted to obd1 and if you are using the correct ecu
Several people I know got hassled for wrong intake box and exhaust manifold.
If the ref knows their Honda then they CAN point it out.
Apparently the refs no longer do the SMOG check so at least that takes some of the worry out of it... but gives the ref more time to hassle you about other stuff.
California sounds like it sucks to own a car there... I can be pouring out black smoke and pissing oil everywhere but as long as my VINs are in the right places I can get my plates and be on my way...
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
NewBorn_EG
Nov 6, 2004 02:13 AM
