No heat, help!
Old Oct 15, 2009 | 02:50 AM
JDMPR's Avatar
Default No heat, help!
Pretty simple, it just stopped blowing out air, could it be the blower motor? If so how do I get to it so I can change it out?
Old Oct 15, 2009 | 02:55 AM
Default_Name's Avatar
Default Re: No heat, help!
don't have a fuse diagram on me, but is there a blower motor fuse under the dash or a relay under the hood for that..? easier and cheaper to replace, for sure..
Old Oct 15, 2009 | 11:35 AM
JDMPR's Avatar
Does anybody know for sure? Need to know cause I work nights and spend most the time in my car freezing
Old Oct 15, 2009 | 01:00 PM
dephtone's Avatar
There should be a fuse under the dash. If that is fine, then you will need to replace the blower motor.
Under the pass side dash it will have a large 2 prong connector, blue and black I believe, unplug that from the motor, remove the 3 nuts/screws and pull it out. You may have to wiggle it, but it will come out, you can test it to make sure its good by hooking a neg and a positive up to it.
Allen Harris
Nov 20, 2016 07:00 PM
JRilez
Feb 3, 2014 04:41 AM
ExtraBlackRex
Dec 16, 2010 03:27 PM
supamike3232
Nov 4, 2008 12:26 PM
TRAY
Jan 31, 2004 05:21 PM
