Suspension & Brakes Theory, alignment, spring rates....
need help finding lower control arms
Old Oct 15, 2009 | 01:23 AM
killaxkev92288's Avatar
Default need help finding lower control arms
hi.. i was wondering if anyone knew where i could find a good pair of rear lower control arms for an 01 civic?
thanks
Old Oct 15, 2009 | 03:31 PM
phunhaus's Avatar
Default Re: need help finding lower control arms
Function 7
Old Oct 17, 2009 | 07:51 PM
dirty19's Avatar
Ridin Dirty in Cali
new , used more specific...?
If new i suggest Hardrace...
Old Oct 18, 2009 | 04:08 PM
new thanx alot for the help ima go look for them now
Old Oct 20, 2009 | 02:30 PM
skunk2.com's Avatar
Here is the Skunk2 LCA. We machine flats in the aluminum so we can use a steel plate to spread the torque of the bolts as well as eliminate the chance of the hardware smashing the aluminum under the head and eventually becoming loose.
We also include the special socket to remove the factory hardware as well as include new hardware to be reinstalled.
Old Oct 22, 2009 | 10:33 PM
beatutful!! just what i was looking for!! do u guys also have the cross member to go with it ??? while im changing out the control arms i mind as well change out the cross members also :D
Old Oct 23, 2009 | 07:27 AM
skunk2.com's Avatar
We offer a lower tie bar, I'll add a pic as soon as I have access to the server, it does a great job of reducing flex at the inner lower control arm mounting points but if you are looking for the really large braces... you'll have to mix product.
Old Oct 23, 2009 | 03:02 PM
that works for me!!! beautiful thanx aloti will be looking in to these parts and getting them when i can.. thank you so much! :D
Old Oct 23, 2009 | 03:07 PM
skunk2.com's Avatar
No pressure... but i want to make sure you knew about a sale we are running this month.
Old Oct 25, 2009 | 10:01 PM
thanx alot again :D
mymomsdrunk
Mar 5, 2008 08:38 AM
yaughtben
Aug 28, 2007 08:56 PM
kyle h.
May 14, 2003 03:29 PM
B18C2_sedan
Mar 9, 2003 08:04 AM
