crx si b20 not starting
Old Oct 14, 2009 | 10:40 PM
slammed4dreg's Avatar
Default crx si b20 not starting
ok to start off, its a 89 crx si, it has a 99 b20b, obd0 dizzy obd0 pr4 ecu the whole harness is obd0 stock si, 94 ls manifold, obd0 stock si injectors with resistor box, has spark has fuel, wats wrong here anything missing???? let me kno thanks
Old Oct 15, 2009 | 05:10 AM
dephtone's Avatar
Default Re: crx si b20 not starting
Are you throwing any codes?
Check your timing, make sure that is spot on. Make sure you have good compression by doing a compression test.
Old Oct 15, 2009 | 09:24 AM
no codes, timing is dead on!!!
Old Oct 15, 2009 | 10:08 AM
EFRue57's Avatar
check your firing order. on your distributor bottom left is #1, top left is #3, top right is #4, bottom right is #2.
Old Oct 15, 2009 | 09:50 PM
firing order is cool!! thanks for everyones input, car starts and stays on if feed carb cleaner threw the throttle body
Old Oct 15, 2009 | 10:31 PM
4drEF's Avatar
Keyboard Humorist
Something isn't adding up.
Are you sure you are getting fuel?
Compression and spark are good
... but it runs on carb cleaner.
What about when you try starting it with the butter fly on the throttle body partially open or completely open?
Old Oct 16, 2009 | 07:52 AM
89LSED's Avatar
Yeah, somethings not right.
If it runns on external fuel then it means its not geting regular fuel.
How do you know its getting fuel?
PSI gauge? or smell it in the cyl/ on the plugs?
Old Oct 16, 2009 | 11:00 AM
placid888's Avatar
check the fuel pressure regulator and the fuel filter
Old Oct 17, 2009 | 11:30 AM
we do have a fuel regulator, and it does have gas, it seems like the injectors are not opening tho. there obd 0 and hooked up with a resistor box they should be good right?? and yea we've tried turning it on with butterfly open wide. were gonna try swapping ecu's, ill let u guys kno wat happens, we just gotta locate another pr4. WILL A STOCK PM6 TURN THE B20 OVER?? WILL IT START AND RUN AT LEAST ALRIGHT??
Old Oct 18, 2009 | 03:40 PM
jcht760's Avatar
New User
i have the same problems as u- same car and motor
Old Oct 19, 2009 | 11:13 PM
bump
Old Oct 20, 2009 | 04:38 AM
dephtone's Avatar
Have you measured to see if you are getting any voltage to the injectors?
There are two basic types of injectors. Low impedance injectors with a resistance of around 2.5-3 ohms, and high impedance injectors of around 12 ohms. This can easily be measured by a multimeter across the two electrical terminals on the injector clips.
onefasthondacrx
Apr 28, 2011 05:50 AM
91SIR
May 1, 2010 10:48 AM
lookout22
Jun 21, 2009 04:16 PM
crx18c1
Mar 19, 2007 09:58 AM
