fuel pump or fuel pressure regulator?
Old Oct 14, 2009 | 07:45 PM
88 EF Hatch's Avatar
Default fuel pump or fuel pressure regulator?
alright you guys here is my problem, i have an 88 dx hatch with an obd1 b16a and new ls fuel pressure regulator and original oem fuel pump. car runs fine on a full tank, as it begins to get lower 1/2 i will feel a bit of a loss a power, but i mean it is very minute, once there is like 2-3 gallons of gas i feel a bit of hesitation in the motor when i drive it normally, not racing or anything. when i race, i feel a bit of hesitation before vtec (4800 rpm on p30 basemap hondata s300). whether tank is full or not, car always takes a while to start when it is cold. it can be warm but if i let car sit for an hour and i go back to try to start, it still takes a while, which i figured is due to loss of fuel pressure. when it is cold, if i try to start car for 1-2 seconds, stop, try it again for 1-2 seconds it will start immediately on the second try, sometimes i have to do it 3 times. i think it has to do with fuel pressure, but unfortunately i dont have a tester. a local mechanic told me that the cycling of the fuel pump at initial start up(when i turn on and turn off and turn back on) definately means its the fuel pump. what do you guys think?
Old Oct 15, 2009 | 06:33 AM
Default Re: fuel pump or fuel pressure regulator?
any body know?
Old Oct 15, 2009 | 06:36 AM
89LSED's Avatar
how long have you had the pump and reg in? and when did you last change the filter?
It sounds like the pump to me, but might as well cheack the easy things first right?
Old Oct 15, 2009 | 03:32 PM
Fuel pump is oem pump, so it has like 200 miles, regulator is brand new one that I bought at autozone, buts for an ls. Fuel filter is only 300 miles old, I just changed it to eliminate that option
Old Oct 15, 2009 | 03:51 PM
4drEF's Avatar
Keyboard Humorist
Could be the regulator for your start up problem.
Let the car sit for about a 30min~1hour after running it and see if you have about the same fuel pressure as if it were running.
(you are going to need a gauge for this)
If the pressure is bleeding off then the regulator isn't working right.
Old Oct 15, 2009 | 04:55 PM
intense4thgen's Avatar
did nobody else catch that he is running a basemap? get the car tuned on a dyno then if the problem is still there start lookin for it.
Old Oct 15, 2009 | 06:58 PM
well why would i need to get tuned if im running stock p30 map and my motor is a stock obd1 b16 with header and intake. and i just swapped my brother regulator, which came off his b16 and it seems to be running a lot better, even on only 2 gallons of gas, im gonna let the motor cool down to see if it starts up without hesitation, and if everything works out good, then i know its my ls fuel regulator that is causing problem
Old Oct 20, 2009 | 06:58 AM
89LSED's Avatar
sooo... Did it fix the problem?
Old Oct 20, 2009 | 07:31 AM
placid888's Avatar
it could be a defective even tho it's new, it happen before
Old Oct 20, 2009 | 05:10 PM
t70accord's Avatar
i believe it is your fuel pressure regulator
Old Oct 20, 2009 | 10:07 PM
yes it was, i used brothers oem b16 fpr and car runs perfect, thanks
JmurGSR98
May 20, 2012 05:26 PM
88 EF Hatch
14
Oct 22, 2009 11:41 PM
88 EF Hatch
Oct 16, 2009 08:54 PM
90TegraB18C
Aug 27, 2006 05:32 PM
