Suspension & Brakes Theory, alignment, spring rates....
Need help 96 accord Drums/Shoes install
Old Oct 14, 2009 | 07:22 PM
HatchSpeeD's Avatar
Default Need help 96 accord Drums/Shoes install
So my G/F's Accord needed some new shoes & a buddy of mine & I who had past experience with drums changed the shoes. This was the first time I ever attempted to work on drum brakes. So it was a real pain in the *** but we eventually got everything on.
Now there is two problems.
1) The driver side rear, was adjusting all the way back but still had a lot of drag on it & could barely spin the 1st few times. We couldn't figure out why & even took the whole thing apart to see if something was wrong but could not pinpoint it. The Passenger rear which actually had the more worn shoes, went smoothly & I adjusted it to a slight drag. Any ideas why the driver side is so tight?
2) The ebrake i'm assuming needs to be adjusted but I don't why & not sure how to do it yet.
So now when you pull it, it goes up all the way up & doesn't really work.
Why would the E-brake have to be adjusted? From how the setup was, I mean we basically just took off the old shoes & put the new ones on. I don't see what could have gotten screwed up. We shouldn't have had to bleed the back after just changing the shoes right?
Any idea's info would be appreciated.
Thanks
Old Oct 17, 2009 | 09:38 PM
cr8ter's Avatar
Default Re: Need help 96 accord Drums/Shoes install
sometimes u do have to bleed them u can try that first...adjust the parking brakes all the way back until the nut sits on the back of the handle when it is down...to adjust it u have to take the center console out on most accords depends what year....then adjust the shoe forks all the way in and start going out with it when u put the drum on it and spin it u want a little bit of drag on it and u should be good....also make sure u got the correct shoes...and check for any kind of binding that might be in the cable mAYBE its kinked up somewhere
apcustom
Dec 7, 2010 02:12 AM
jthrasher1
Aug 18, 2010 01:07 PM
Rylassassin1
May 18, 2004 03:18 AM
