Does the throttle cable need to be changed?
Old Oct 14, 2009 | 07:22 PM
bori bori's Avatar
Icon2 Does the throttle cable need to be changed?
I am currently swapping an LS into my EK hatch, and I was wondering if I would need to change the throttle cable to an LS one or would the single cam one work fine? Your input would be greatly appreciated, thank you.
Old Oct 14, 2009 | 07:24 PM
R666_EK's Avatar
Default Re: Does the throttle cable need to be changed?
Y7 or Y8?
Old Oct 15, 2009 | 07:16 AM
tlarimer's Avatar
I dont know on the EK, since I own an EG, but when I swapped an LS into my EG getting the LS cable was a $15 piece of mind.
Old Oct 15, 2009 | 02:57 PM
R666_EK's Avatar
If there was a Y7 in there you will need an ls or y8 cable.
If there was already a y8 then you're good to go.
Old Oct 15, 2009 | 02:59 PM
98civdx's Avatar
Master Detailer
its is a y7, get a 99-00 si throttle cable
but a y8 will work.
Old Oct 15, 2009 | 06:32 PM
bori bori's Avatar
yes its a y7, so I have to get an SI, LS or Y8 throttle cable then?
Old Oct 15, 2009 | 10:38 PM
Import_spoon's Avatar
yes get a B series cable. DA's and Dc works.
Old Oct 15, 2009 | 11:51 PM
tEKnics's Avatar
DO NOT get a gsr throttle cable. Listen to the man above. Si (b16) y8 or ls.
Old Oct 16, 2009 | 03:11 AM
hondamark35's Avatar
getting a Y8 or LS cable is ideal, however the Y7 will work properly you'll just have a lot of extra cable to deal with and tuck out of the way.
since it seems to be cheap and simple, go for the Y8
Old Oct 17, 2009 | 04:59 PM
bori bori's Avatar
cool, thanks guys
Project Dad
Mar 28, 2011 04:12 PM
Project Dad
Mar 13, 2011 01:35 PM
hondadda
Oct 6, 2007 06:49 AM
GREY_EK96
Jun 30, 2005 02:50 PM
dogfood
Jun 1, 2004 02:47 PM
