some stuff for cheap d series stuff
i have paypal hit me up on AIM or yahoo messenger
I make these one by one they are good quality.
Also mine are very easy to hook up. Not a bunch of BS wiring
all oem wiring and plugs
40 shipped
will knock of a little for obd0 ecus
like new non vtec wires 7mm 20 shipped
Not pictured are
1.5 pan and pick up slight scuffs on pan 25 shipped
pistons pm3 with rods under 1000 miles 30 shipped
1.5 crank perfect condition 60 shipped
water pump from my b1 under 1000 miles 15 shipped
oil pump and rear main from a b1 should fit the a6 also and maybe others as well both didnt leak and work great
40 shipped for both
small bearing diff from a cable trans 30 shipped
y8 need gasket and screen 20 shipped
small diameter clutch set comes with what ya see disk is pratically new
50 shipped for all 3
harnes from headlight to behind the seats from a 88 crx hf. engine harness is missing plugs like injectors dizzy resistor
dash harness seamed to ok 60 shipped
this would be good for a entire harness swap for a mpfi swap on a 88-89 crx or civic. Just need to add the plugs. some are depinned some are cut off
like new aftermarket cats use for whatever 30 shipped each
12 shipped pending
obd1 12 shipped can add injectors for a extra 10.00
25 shipped this is powder coated not paint
D series cable forks missing 3-4 fork 25 shipped
1.5 pan 25 shipped powder coated if ya need pics of the inside let me know
40 shipped
Not pictured are
40 shipped for both
12 shipped pending
