can you use a pm6 in a dx?
Old Oct 14, 2009 | 02:56 PM
724chris's Avatar
Default can you use a pm6 in a dx?
my buddys car got flooded and his ecu got ruined.its a dx and yes i know they use pm5s. but i have a pm6 si ecu laying around and i was wondering would it work in his dx?
Old Oct 14, 2009 | 03:07 PM
lynchjdm's Avatar
Default Re: can you use a pm6 in a dx?
im pretty sure the pm5 is dpfi while the pm6 is mpfi..
Old Oct 14, 2009 | 03:09 PM
dacrxguy's Avatar
nope unless you mpfi it
Old Oct 14, 2009 | 03:17 PM
sanimalp's Avatar
$cat /dev/urandom
definitely not, unless you convert to mpfi. It is probably MUCH cheaper just to find another pm5.. People practically give them away.
Old Oct 14, 2009 | 03:28 PM
dacrxguy's Avatar
i wish they gave them away were i am from people here think pm5 are worth more than 20 bucks
Old Oct 14, 2009 | 03:35 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Around me they go for about $50 because everyone and their Mom want to do an automatic to manual conversion... but they still keep it DPFI...
Old Oct 14, 2009 | 03:41 PM
BiG ChOr!Zo's Avatar
Old Oct 14, 2009 | 03:52 PM
4drEF's Avatar
Keyboard Humorist
I have one for sale. (check link in sig.)
Not sure if it's auto or manual... seems to be manual, but I keep getting conflicting answers when I search and I haven't opened it up to find out.
Auto should run on a manual car - throws a lockup solenoid code though.
You sure the flood killed the ECU?
Have you tried opening it up and drying it out?
It's manufactured with the entire board being sprayed down with a protective conformal coating that keeps out moisture. Should keep everything dry except the connectors.
Worth opening up and looking for burnt parts.
Old Oct 14, 2009 | 03:55 PM
DO IT ON ALL FOURS
^^^ It does not have the sticker on it any more? ^^^
Old Oct 14, 2009 | 04:06 PM
4drEF's Avatar
Keyboard Humorist
It does. Problem is that 37820-PM5-L80 is coming up as manual tranny AND California emissions auto tranny.
I had 2 PM5's. One came from my stock Cali LX auto and the other was from a manual DPFI.
I destroyed one of them and used the plugs to make an OBD1 jumper harness... not sure which 0_o
Guess I have to open it up to see what it is.
Old Oct 14, 2009 | 05:54 PM
dacrxguy's Avatar
sound so familiar but i almost have a mpfi swap
and yes i am tired of looking at my check engine light
Old Oct 14, 2009 | 10:15 PM
sanimalp's Avatar
$cat /dev/urandom
L80 is automatic. if the last 2 digits are 50 or higher, it is an auto.
impr323
Jun 13, 2009 02:27 PM
G U E C O
Jun 5, 2006 02:43 PM
vegaskurt
Jan 12, 2005 04:33 PM
japrex
13
Aug 1, 2004 07:57 PM
pinoyboy204
Jul 18, 2003 08:26 PM
