Can't remove a open-ended lugnut from my wheel! Please advise!
I have an open ended lugnut that has been rounded off on the inside by an impact/air wrench and can't remove it with the key. (The key cannot grab the inside of the lugnut)
What can I do to remove it now?
This picture is just for reference. This is the type of lugnut and key I am talking about. But the one I have is a Zenki aluminum lugnut.
Either weld or hammer something that fits in there and get it out that way. Maybe you can find a pretty big 'easy out' like this.
http://media.uxcell.com/uxcell/image...x0076_ux_c.jpg
hammer it round with a screw driver?
smack a slightly smaller socket over it and then undo it with a ratchet?
or drill it off? carefully and you wont have to replace the stud
I've never used JB Weld before in my life. Would the epoxy really be able to bond the bolt to the inside of the lugnut, strong enough to withstand 80+ pounds of pressure/torque?
get a socket that's very close to the lug nut size and pound it on like the guy said it works. I do it in work all the time when morons lose their keys.
If its a cheap aftermarket lug nut then you might be able to break it off. Otherwise I would suggest as the others have, and pound a socket on there. The vice grips MIGHT work but as you said, its completely smooth and probably not a good surface for it to grip.
