91 Integra Ls b16 swap roblems??
Old Oct 14, 2009 | 02:36 PM
91TegDa's Avatar
New User
Icon2 91 Integra Ls b16 swap roblems??
I have a 1991 Da and i am trying to put a b16a2 out of a 2000 Honda Civic Si engine in it. I have converted alternator dizzy (hardwired) have obd 1 and 2 ecu not sure which one to use and my injectors are now obd1 also. I am aware that the knock sensor does not have a plug in considering i am using the stock ls harness but did not know if it would effect it. I am getting no spark and no power to the fuel pump what so ever. I have checked my fuses to the ecu and to fuel pump and they are both good also changed the relay because thought that the relay could be bad. Was told by slowmo that if i took the top off the ecu that a light would turn on if there was power getting to it. There was no light that had came on. Any ideas of the cheapest//easiest way to configure my problem?
MervTeck
Feb 23, 2017 03:57 PM
91stocksi
53
Oct 19, 2012 05:56 PM
laoboisosilly
14
Jul 14, 2009 06:01 AM
oldschoolef9
May 29, 2007 04:19 PM
Jeff C
Aug 22, 2002 05:15 AM
