obd0 to obd1 dash loom conversion in 89 crx sir
Old Oct 14, 2009 | 11:43 AM
civicboyvtec's Avatar
Default obd0 to obd1 dash loom conversion in 89 crx sir
hello,
wanted some info on changing the loom on 89 crx sir currently runing obd0 dash loom but am thinking of changing it to obd1 as i have done it on couple of other car before and i dont mint doing it again, but before anyone says run conversion harness i have done that and i dont wanna do it again,
so basically my simple question is, is it possible to do the obd0 to obd1 dash loom conversion on 89 crx sir?
thanks Amer
Old Oct 14, 2009 | 11:52 AM
D16SiHatch's Avatar
Default Re: obd0 to obd1 dash loom conversion in 89 crx sir
the obd1 harness plugs will match most likely nothing on your crx dash. not to mention the dash harness is also apart of the headlight harness and i'm not sure how you'd go about connecting the two. is it possible, sure. but why would you want to, and how does using the obd1 harness make anything easier or better?
jdmerda9
Feb 12, 2010 11:50 AM
91EF_Si
13
Jul 3, 2007 04:27 PM
E_F_9
Dec 25, 2005 07:36 PM
soundman
10
Nov 14, 2003 07:59 PM
Hondasaurs
Mar 30, 2003 04:37 AM
