CAR WONT TURN ON H-T HELP PLEASE!
well it started yesterday my car was acting perfectly fine it would start up with no problem or hesitation so i go to my friends house turn my car off come back 15 minutes later to see that my car wont turn on, its not the battery because i had triple A come out and they tested my battery and they said it was good, now i turn my car on half way and the radio goes on and my dash lights come on but once i tun it on all the way the radio, etc. turn off my motor makes no effort to turn on the guy from triple A said it was probably my starter, if you guys could help me out to see what else the problem might be before i buy the part for the car and it not it thanks in advance for everyone that helps out
are you saying its not cranking over at all. Is it a manual transmission. If so I would check the top clutch switch. If the button fell out that activates the switch it will not let the car start because it thinks the clutch isnt pressed in
Im going to go with about 90% of hondas do this at one time. Mine just did it at walmart about two weeks ago. That stupid button is 6$ from honda. And its tricky to get in. Some people just unplug the top yellow clutch switch and jump it. I used a bobby pin, complementary to the wifey at walmart.
cause my car not starting was random especially since it wasn't giving me any signs of a problem turning on
c00ker
Honda Civic (2001 - 2005)
Jun 23, 2011 06:45 PM
Stunna MIKE
Jan 19, 2011 07:08 PM
dontlooknow
Jun 3, 2008 02:06 PM
