Saab turbo injectors?
Does anyone know if their turbo injectors compatible with any honda's? if so will i need a resistor box...
thanks,
mike
P.s.
i searched and could not find any info!
thanks,
mike
P.s.
what injectors are you looking at specifically? are you looking at buying them?
from what I found they are usually bosch injectors, however, I couldn't get a flow rate..
as far as fit, someone could probably tell you better than I can if they will work..
my question to you would be why use them? As far as using "other" injectors, DSM and evo injectors are fairly common and can be had for a decent price.. are you looking at them because they are cheap?
check the marketplace too.. lots of good deals on injectors.. you just have to keep your eyes peeled..
i picked them up from a salvage yard for $20 bucks. their from a saab se 900 turbo. i believe their 360cc. are they worth trying to use, will they work, and has anyone tried or have any info is what im wondering...
I haven't heard of anyone using them... maybe check with jk tuning or phearable and see what they have to say.. they would deal with this type of stuff a fair bit...
what kind of setup are you running? If they are 360cc, unless you are running a small output goal, chances are you will need something else anyways..
