What can it be?
Old Oct 13, 2009 | 08:46 AM
dj-t's Avatar
Default What can it be?
I have a 90 civic si with a 91 b18a. I purchased new DA axles to replace the old ones but, the problem that I ran into is that when installed on the passenger side my wheel does not spin as freely as on the driver side. I thought it was maybe a bad caliper took it off but still the same thing. Thought it was the transmission pulled the axle out of the hub and turn it by hand with the axle still in the transmission it spun just like the other side. The only thing that i can think of right now is that maybe the wheel bearing is going out. Threw everything back on and drove it and it drive pretty much the same. Am I missing something here? What can it be?
Old Oct 13, 2009 | 12:39 PM
zsoccerdude17's Avatar
Default Re: What can it be?
honestly the wheel bearing would have been one of my first guesses
Old Oct 13, 2009 | 01:03 PM
brownsEF's Avatar
were both the tires off the ground?
Old Oct 13, 2009 | 01:13 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did you remove the rubber O-ring on the new axles?
Old Oct 13, 2009 | 02:56 PM
88whitehatchidaho's Avatar
did you remove the dust ring not sure if it has to be done with that set up but am pretty sure it does had same problem on my swap i just spaced out on removing them
Old Oct 13, 2009 | 02:59 PM
KWayRacing's Avatar
^ above remove dust rings
Old Oct 14, 2009 | 07:42 AM
dj-t's Avatar
As for that rubber ring, can I just use a flat screw driver to pry it off? What are the cons of leaving it on?
Old Oct 14, 2009 | 08:39 AM
DO IT ON ALL FOURS
You can use whatever you want to take it off... A screwdriver, knife, stick, fork, bolt, fingers, ect ect just take the thing off. How would there be any Cons? It wasn't designed to be on that car otherwise your stock axles would have them.
For those saying the dust cup: most of the time your axle will not spin at all with it left in. His axles spin so most likely it is the rubber O-ring that comes on some new axles. Either way OP if you left the metal dust cups on take them off any way... (see above list for things you can use)
wunPOINTeight
Jun 15, 2021 06:37 PM
SQ is the SQUAD
Suspension & Brakes
May 31, 2011 12:06 PM
freezy
11
May 9, 2011 02:19 PM
KaoticSnow
15
May 17, 2005 11:54 AM
CRX7
Nov 20, 2002 12:55 PM
