Will vx wheels fit over integra rear disc conversion, and one other brake question.
its all in the topic, just curious because i already have the conversion but this just crossed my mind.
also, is it difficult to install the integra master cylinder and prop. valve on my 92vx? any modifications required or do they just bolt up?
VX rims are 13 inch rims.
Hrmm. . .. Are they the same as the EJ HX wheels? Which are 14"?!?! Am I delusional er sumfin? 13" wheels.. hmm that would make since why they wouldn't fit the front ;-) I'm gonna check when I get home . . .
"AHEM" anyone know if they will fit? and what about the master cylinder and prop. valve Q?
[Modified by blufke, 2:15 AM 8/30/2002]
Prop and master cylinder? Asked and answered.
The master cylinder of a non-ABS teg is a synch. The proportioning valve is a pain in the ***, I have done two on mine (leaks) and it's very tedious work. Have a nice assortment of tools including a 10mm plumbers flare nut wrench (forgot the name of that tool).
about that master/prop question. the master will not bolt up to the stock booster. you need the master/booster off an integra. if you get a 94-97 master/booster, then you will need to reflare one of the fittings as it is larger than yours. if you get a 98+ master/booster, then it is all good. ABS doesn't matter AT ALL, any teg will work. you need to get a prop valve off a NON-ABS car though. best bet is 90-93 integra. if you get a 98+ then it will be easy as hell (as long as you can get the nutz off ok, use flare nut wrench, i had to resort to ******* vice grips after my shitty flare nut wrench flexed and stripped some of the bolts). if you get a pre 98, then you will need a flare tool and i don't know how hard that is since i got a 98+ so as to avoid that **** yo.
[Modified by ndogg, 10:22 PM 8/29/2002]
ive got a 93 prop valve and mc but no booster. noticed i needed the booster when i saw the mc wouldnt bolt up right. where is a good place to get one?
Vx Wheels are 13"s and dont clear disc brakes
Hx Wheels are 14"s and do clear disc brakes
Some guy was telling me he had to sell his vx wheels when tried to put them on his 99 si because they didnt clear, and he picked up hx wheels because they did, hope that helped some.
i got all my stuff from a local wrecker. i am lucky and have HUGE all honda/acura wrecking yard right by me. only thing that sucks is that it isn't a "pull it yourself" place so you can't take all the little things. the only place i know of online that sells them is sohfast.com. i've never done buisness with them so i can't vouch for them. i do know that they are pretty expensive though. and i'm 99.999546% sure that the 13 inch, yes thats 13, vx wheels will clear the rear and not the front. so if your only doing the rear, you be aight.
have my tiny *** discs up front. they will stay that way. just wondering about the rears. i imagine the rears are not much bigger than the stock fronts.
HX 13" wheels will fit Integra Rear Discs.
note, the 13" will not fit the frotn Integra Discs without using a spacer.
note, you got stock discs up front still on your civic, so you should be all set
so will the 13s fit stock teg rears? im thinking they should.
Hanmin
Nov 7, 2009 11:04 AM
RED95EG6
Oct 7, 2007 06:40 PM
