Pre Swap Help
Old Oct 12, 2009 | 05:42 PM
Tyson.'s Avatar
Icon4 Pre Swap Help
Alright going to be doing a simple b16a swap into my 90 crx si just want to get everything i need befor i put the work in (hate doing it and forgetting somthing)
im going to list everything i think i need just need a little help on some things.
Getting motor from hmotorsonline this one. http://hmotorsonline.com/shop/sc2000...age&item=30004
motor mounts http://hasport.com/store/index.php/m...s-ef/efb2.html
shift linkage http://hasport.com/store/index.php/efblink.html
things i need to know is axles i its going with the lsd tranny so it's y21 or s21 and i dont know what axles to use. and were can i get the rear tran. mount?
on the cable to hydro set up i was going with hasport also
http://hasport.com/store/index.php/cma.html but im not sure is this thing needed? http://hasport.com/store/index.php/efbhcl.html
rywire obd0-obd1 http://rywire.com/store/obd0-obd1-co...e5eaee54c43803
not sure if anything elce is needed but thats all i got as of now also going to be replacing water pump, timing belt, and plugs and wires . anything elce i need?
Thanks
Old Oct 12, 2009 | 05:47 PM
1kleenef's Avatar
Default Re: Pre Swap Help
ecu, rear trans mount is different, and wiring...
Old Oct 12, 2009 | 05:54 PM
Tyson.'s Avatar
damn knew i forgot somthing ill add rywire to it also it comes with ecu any idea on were i can get a trans mount?
Old Oct 12, 2009 | 05:55 PM
crx_si-r's Avatar
as far as the axles go, my buddies and i are all using 88-89 integra axles. and my buddy is swapping back and forth between an LS transmission, B16 transmission and an LSD transmission all with the same axles. what you have to remember is your axles have to match your intermediate shaft (the mid axle that bolts to the motor).
Old Oct 12, 2009 | 05:56 PM
crx_si-r's Avatar
when/if you go with rywire all you need is a vtec subharness. for the rest you can re-use your stock harness
Old Oct 12, 2009 | 06:13 PM
Tyson.'s Avatar
the sir II is obd1 going to need the converson right? if i wanna just plug it and go with out hard wiring it?
Old Oct 12, 2009 | 06:52 PM
crx_si-r's Avatar
well, you oem harness will plug right in to the sensors, i think on the throttle body mounted map sensor you have to switch some wires but i dont remember. you will only need to add the following wires:
4wire o2 sensor (if your going obd1)
knock sensor (unless your ecu has this disabled)
vtec solenoid
vtec oil pressure sensor
and you will have to cut and extend the wires from your fan switch (located on the back and to the top of the oil filter on obd0 blocks) to the thermostat housing where the sensor is located for the 92+ civic and integras
Old Oct 12, 2009 | 07:10 PM
crx_si-r's Avatar
sorry i didnt notice you said the motor was obd1. if you are going to convert you will need what i posted above. in addition you will also need the obd0-1 ecu jumper harness. this harness will have all the wires needed you will just need to go to the junkyard and get the proper plugs unless you get one that already has the plugs
madgeo
Apr 25, 2009 05:47 PM
JDM_Frijoles
Aug 20, 2006 12:59 PM
CRX-SIR
11
Jan 23, 2005 12:47 AM
LS REX
Jul 23, 2004 07:21 PM
Dainbramage
Apr 25, 2004 08:06 AM
