Are my times somewhat on par....stock gsr on 7psi
Old Oct 12, 2009 | 05:25 PM
brian15's Avatar
Default Are my times somewhat on par....stock gsr on 7psi
Just getting this set up going.
stock jdm gsr
victor x manifold ( edelbrock 65mm tb )
custom ramhorn manfiold with a garret gt35r
3 inch exhaust dumped before the rear tire
s300 with a safe safe base tune from another car
750 injectors
car is a 95 civic that weighs 2500 w me in it with a jdm gsr trans and exedy clutch
60ft was 2.10
1/8th 8.50 @ 89 mph.
so my question is with this turbo at 7psi is it really holding back the cars potential. Im also trying to determind what i should shift the car at , it seems like my s manager is 500rpms lower than the vehicles tach at idle.
any advice or input is welcome.
Old Oct 12, 2009 | 05:31 PM
SonicRacing1's Avatar
Default Re: Are my times somewhat on par....stock gsr on 7psi
60ft was 2.10
1/8th 8.50 @ 89 mph. was this on slicks or street tires
Old Oct 12, 2009 | 05:42 PM
brian15's Avatar
Originally Posted by SonicRacing1
60ft was 2.10
oops left that out , falken street tires on rota's
Old Oct 12, 2009 | 05:58 PM
13173's Avatar
I would say that was just about on par.......I ran similar times to that 5-6 years ago in my 92 SE-R on cheap street tires. Actually, they were Kumho Ecsta 711's I think. That 60' is not to terribly bad for straight up normal street tires. I think I cut some 2.0's on mine, but it took some practice. Im sure I made less power than your car is currently making (stock T-25 pushing 9psi) and my mph was lower than yours, but I think the ET was close.
boostedcivicsir's Avatar
Mr. Badwrench
7 psi on a 35r? that turbo isnt even happy yet....and the safe safe tune base for another car scares me.
Old Oct 12, 2009 | 06:20 PM
haas480's Avatar
purchase rods n pistons. turn up boost. 8-9k. tune job. go faster, be happy =]
Old Oct 13, 2009 | 03:27 AM
brian15's Avatar
yes just a 7psi spring in the wastegate at the moment, the tune is off the car that the turbo set up came off of , so there really is only minor difference ( not idea but it works for now ) and i do have a wideband in the car at all times.
Old Oct 13, 2009 | 05:46 AM
hybrdthry911's Avatar
Do you have a boost gauge in the car? Does it hold 7 psi.
Old Oct 13, 2009 | 05:55 AM
Turbo-charged's Avatar
is this the purple coupe? if so be careful running on coreys map, his car had substantially less compression than your car. get that thing on a dyno. a tune is a lot cheaper than an engine rebuild!
Old Oct 13, 2009 | 07:54 AM
brian15's Avatar
i do have a boost gauge and i datalog....the most the car has seen is 7.6lbs
Old Oct 13, 2009 | 07:56 AM
brian15's Avatar
i plan on seeing you as soon as funds become availabe.
Old Oct 13, 2009 | 08:02 AM
h2b_sedan's Avatar
get that beast tuned man... probably running a little bit on the lean side with that compression!!!
pompom
Mar 16, 2006 07:51 AM
b18c195
Oct 18, 2005 06:14 AM
xprohx
May 20, 2004 08:22 AM
comptechgsr
Feb 18, 2002 04:05 PM
