alternator not charging, there is not battery light?
Old Oct 12, 2009 | 02:46 PM
ONE*SICK*FERIO's Avatar
Default alternator not charging, there is not battery light?
yesterday my car died then i tried to turn it on but the battery was drained
so i changed it and used my volt meter to see whats wrong...
the car off the volt meter was reading 11.96, then turn it on still reading 11.80,
if i rev it the voltage drops to 11.60 and keeps going down so its my alternator but im confused because my battery light is not ON.
always when the alternator fail the battery light turns on....right?
is there any fuse that i need to check?
all the fuses on the engine bay are fine,belt is good, connections to the alternator are fine i didn't mess with the car or anything, it was running great...
any input thanks...
im pretty sure the alternator is gone but before i take it out to autozone and test it
hope is something else...
thanks
ed
Old Oct 12, 2009 | 02:55 PM
Default Re: alternator not charging, there is not battery light?
i turned the car ON an disconnect the battery the car shut off right away.
im going to check the fuses inside ..........
Old Oct 12, 2009 | 03:21 PM
gwl's Avatar
gwl
I heard its not a good thing to disconnect the battery while running. I don't know if that is true. On older cars without the computers it was alright. Since it died when you disconnected the battery, it point toward your alternator. You can have it tested at Autozone and the such. Many years ago, Sears used to do free bat/alt check in the car.
Old Oct 12, 2009 | 04:38 PM
h2b eg's Avatar
it prob just needs an alt. i would just replace it..ive also seen a few cars have bad alts and the batt light not be on
Old Oct 12, 2009 | 04:41 PM
MHDesigns's Avatar
Check #15 under the dash first. I had this problem. Change it whether it looks good or not.
Old Oct 12, 2009 | 06:03 PM
i change it and nothing.....
took the alternator to autozone to test it n didn't pass
lifetime warranty ftw!!!
problem solved...
Dj HeetazMalone
Classic Hondas
Jun 15, 2017 07:24 AM
hondakidd23
Honda Civic (2001 - 2005)
Jul 2, 2012 05:27 PM
tyvtec23
10
Feb 10, 2012 11:22 AM
busha61067
Feb 10, 2010 04:54 PM
Martaigne
Jul 14, 2002 04:19 PM
