Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
need some good brakes
Old Oct 12, 2009 | 11:55 AM
civic5axl99's Avatar
Icon2 need some good brakes
alright guys i need your input on this one. 01 em2. need front pads and rotors. i drive my car hard so i need to stop too. every once in a while i'll go to the track but not a whole lot. at the same time i dont care too much about dust but really hate the squealing. what should i get? i was looking at some akebono ceramic pads and some brembo slotted rotors...
any input will be most appreciated. thanks
Old Oct 12, 2009 | 12:13 PM
b0yg0tskills's Avatar
Default Re: need some good brakes
get some drill slotted if you need to stop hard
Old Oct 12, 2009 | 12:44 PM
popee's Avatar
brembo blanks/ hawks pads
Old Oct 12, 2009 | 01:21 PM
Honda Rules's Avatar
Hawk HPS..do not get they dust like crazy
Old Oct 12, 2009 | 05:14 PM
bomerman19's Avatar
the drilled and slotted rotors will take longer to stop on the em2 and hurt your braking performance this has been tested before.
HPS don't get that dusty and are a great street/ auto-x pad if your looking for a little more get the HP+ but they do squeal and do require some heat to get them to grab
I would stay away from cobalts as they eat through the finish on rims and seriously disappointed in the build quality
Old Oct 16, 2009 | 12:01 PM
so which hawks should i get? or do they all sqeal?
Old Oct 16, 2009 | 12:10 PM
Boilermaker1's Avatar
Autozone rotors (its a lump of iron, so just get the cheap ones), and axxis Ultimates have always been my brakes of choice. For the track, especially, use the cheap rotors, they cost less to replace when you cook them, and they're all done for in about the same amount of time.
For the track, the pads are alright as long as you can give them some time to cool off between heats, but I would expect them to get a little hairy by the end of the day...
I've played around with both the hawks (HP+) and the axxis pads and prefer the axxis pads for 2 reasons... first, they dont make as much noise or dust, but thats relative.... dont expect them to be clean, and second, because the are far better with pedal modulation. I've found the hawks to be either on, or off, with very little room for finesse in between. Currently I'm running Ultimates on the front, HP+s (had them laying around) on the back (SI brakes)... and the noise from the rears is annoying as hell.
Old Oct 19, 2009 | 07:27 AM
bomerman19's Avatar
yeah Hp+ are loud I never had any problems with hps up front though
Old Oct 21, 2009 | 02:20 PM
elcentrobaby's Avatar
Other than pads and rotors, have you considered upgrading to stainless steel lines? I've heard it provides a huge difference in stopping power and should not be overlooked.
mingus
Honda S2000
22
Feb 20, 2008 12:23 PM
sony224422
Aug 13, 2006 04:30 PM
Trellis
Mar 12, 2003 04:50 PM
manson
Apr 26, 2002 02:40 PM
