Timing wire jump odb0-odb1 conv.
Old Oct 12, 2009 | 11:10 AM
solo2hatch's Avatar
Default Timing wire jump odb0-odb1 conv.
I searched the archive and this subject seems up for debate. Im setting the timing on my 89 std hatch with a d15b7 on a p06 odb1 ecu. When I'm setting the timing do I use the D4 to D22 jump (connector 2P) that is discribed in the manual from the 92 book or do I jump the service connector that is on my drivers side front inner fender. Has the connector on my fender been made obsolete by the ecu swap and repin? I have tried it and the jump on the fender turns on my CEL on but, is this correct?
Old Oct 12, 2009 | 02:00 PM
solo2hatch's Avatar
Default Re: Timing wire jump odb0-odb1 conv.
anyone?
Old Oct 12, 2009 | 02:33 PM
4drEF's Avatar
Keyboard Humorist
You could do a continuity test and see if D4 and D22 go out to the connector on your fender.
jwarren1904
Feb 9, 2014 03:17 PM
AnitRiceSuperStar
Feb 18, 2004 09:42 PM
USDM 4G VTEC
10
Jul 4, 2003 06:26 AM
type Gendy
May 18, 2003 02:53 PM
fe519
Nov 23, 2002 03:55 PM
