screeching noise at start up.
Old Oct 12, 2009 | 10:48 AM
gohonda's Avatar
Default screeching noise at start up.
when i start the car it makes a screeching noise but when i give it a little push of gas it stops.
99 civic
Old Oct 12, 2009 | 10:53 AM
gwl's Avatar
gwl
Default Re: screeching noise at start up.
Tough to diagnose without really hearing it. Can it be the alternator or AC belt? Shoot some belt dressing spray to see if it goes away. If it does, you need to retension the belts or get new ones. Also, does it sounds like starter solenoid getting stuck?
Old Oct 12, 2009 | 11:16 AM
Simkin314's Avatar
I would lay money you need to re-tension one of your belts (i.e. A/C, Power Steering, Alternator).
Old Oct 12, 2009 | 04:11 PM
h2b eg's Avatar
i would put belt dressing on the belts but i like to use just candle wax as it doesnt fling oils all over the bay but u either need new belts or re tighten them
Old Oct 12, 2009 | 06:10 PM
Arthas's Avatar
Please dont follow h2beg's advice. The dressing could cause your belts to wear prematurely and possibly make them break.
Your belts need re tensioning, that is all. Give each of them tension with your hand and see which one is loose the most; then loosen the 14mm bolt, giving it tension, and then tighten it.
Old Oct 12, 2009 | 06:18 PM
noboosthatch's Avatar
New User
Def have a loose or worn belt
Old Oct 13, 2009 | 02:08 PM
h2b eg's Avatar
damn it i really should proof read my post i ment to say i WOULDNT..do to what arthas said..dressing will also make the belt skeech even worse with in a few days
Old Oct 13, 2009 | 03:34 PM
ferio252's Avatar
^werd.
Old Oct 28, 2009 | 10:16 AM
gohonda's Avatar
You have to losen the 14mm bolt, which gives it tension then you tighten the bolt again?
F@llon58
Jun 1, 2017 07:39 AM
mclasser
Aug 24, 2015 08:02 AM
transitions
Jul 28, 2005 08:33 PM
stRtypR25
Sep 26, 2002 03:01 PM
B18C-RnVA
May 18, 2002 02:06 PM
