91 civic door handle removal?
Old Oct 12, 2009 | 10:32 AM
Captain Key!s's Avatar
Default 91 civic door handle removal?
Heya,
My car was vandalized/attempted theft on Saturday. They took a tapered drill bit to my door lock/handle on my drivers side and tried to drill it out. I ordered the new parts from Honda today (new handle,bezel and key cylinder). I tried to search for a DIY write up on this year (only found newer models w/ power).
Does anybody have a link or any tips to make this an easier process? Thanks!
Old Oct 12, 2009 | 11:02 AM
sleepingciv's Avatar
Default Re: 91 civic door handle removal?
remove door panel
look inside door on the backside of the handle there should be 2 10mm nuts remove those
then there will be a rod attach to the handle remove that
install in reverse
remove door panel
install in reverse
Old Oct 12, 2009 | 12:56 PM
4drEF's Avatar
Keyboard Humorist
If you have an alarm with remote entry you can use the sedan rear handles and delete the locks entirely
Old Oct 13, 2009 | 09:29 AM
I figured that's what I needed to do, but wasn't too sure. Thanks...
Old Oct 13, 2009 | 09:34 AM
mikesrex's Avatar
Originally Posted by sleepingciv
remove door panel
install in reverse
yeah it's not too bad. sleepingciv basically described the general procedure.
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
todd.ludwig
May 1, 2006 02:27 AM
truckhigh
10
Jun 7, 2005 06:09 AM
teg95
May 22, 2002 01:16 PM
