2.25" gasket on 60mm exhaust okay?
Sucks having 60mm exhaust because the 2.5" gaskets are too big and the 2.25" gaskets are too small.
The bolt holes on the 2.5" gaskets are too wide apart. But the 2.25" gaskets are spot on.
So the gasket will be 3mm too small for my exhaust, so theoretically it will decrease exhaust flow, but more importantly, will the gasket last like this?
I would buy 60mm replacement gaskets if time weren't an issue, but it is. Otherwise, I can go to the store and buy a couple of 2.25" gaskets.
I need opinions and answers.
Problem solved.
I bought 2.25" gaskets, the bolt holes were too wide apart on the 2.5" gaskets.
I sized it on my 60mm exhaust and it's just about perfect anyway.
