Drag brakes/Over Heating.
Old Oct 12, 2009 | 10:21 AM
LS-VTEC-TURBO-EF9's Avatar
Default Drag brakes/Over Heating.
Ok so... my car starts and turns on and runs finally. Only problem is that im having an over heating issue.When i turn the car on and let it idle for 15minutes the needle rises past the middle and above. I did a wire tuck recently so i got rid of my heater core hoses. So i re-routed the one from the side of the head to the back of coolant tube (that sits hehind the block. Im not sure if the re-routing has anything to do with it. The thermostat is brand new.
Its a freshly put together motor. With no coolant leaks. Ive made sure that there is enough coolant and everything. downpipe has heatwrap. Exhuats side has blanket. Hood is off. 14" high cfm fan is coming on. I just dont get it.
Any suggestions.
SECOND QUESTION
Im running 13" lensos for the drag strip and looking for an upgraded braking system. But everything is way bigger. What are you 13" lenso guys running?
Old Oct 12, 2009 | 02:24 PM
Default Re: Drag brakes/Over Heating.
50 views and no help? i know tons of vire are running the 13" lenso.
And im sure some of you have had Over heating issues
Old Oct 12, 2009 | 02:34 PM
narfdanarf's Avatar
I run the stock brakes that came on my 99SI whatever those are. They work fine for me with upgraded pads.
Old Oct 12, 2009 | 02:36 PM
Innes's Avatar
stock brakes work fine for pretty much everyone
i know some, i included are in fact running drums in the rear too and we have no stopping problems
put a set of good pads in place and call it a day
Old Oct 12, 2009 | 02:59 PM
SonicRacing1's Avatar
The stock brakes are fine i recommend HAWK brake pads or at the very least OEM HONDA pads
Old Oct 12, 2009 | 03:01 PM
boosted91crx's Avatar
GSR brakes are just about the largest that will fit under most 13 inch drag rims.
Old Oct 12, 2009 | 05:15 PM
jnv255's Avatar
is the fan blowing the correct way?
Old Oct 12, 2009 | 05:25 PM
ALL IMPORT's Avatar
ive gone through this already & your S.O.L. sorry. thier really isnt anything out their for our cars as far as SMALL brakes. just get good pads.
if miller can do 170+ & stop so can u. lol
Old Oct 12, 2009 | 05:42 PM
JBLAZE622's Avatar
im running stock GSR brakes and stop at 140+ with no problem and that is with only front brakes.... as far as the over heating issue i had the same problem with my car ever since i sleeved it the only thing that i noticed helped was make sure you bleed the system good and when i put a FAL fan and fluidyne RAD the over heating stopped .i also just capped off my heater core lines
Old Oct 12, 2009 | 06:04 PM
Who exactly did you cap it off??
Old Oct 12, 2009 | 06:07 PM
SPOOLINmatt's Avatar
Ive seen a lot of cars with all of the lines capped off, I had my lines looped but today i capped everything and plugged the holes in the manifold and head for heat and IACV. It shouldn't overheat because those lines just recirc to the same place and the same water.
Old Oct 13, 2009 | 06:31 AM
Well, i pulled the thermostat and everything went well. The temp didnt rise above the median. I can conclude that it was a faulty thermostat.
Old Oct 13, 2009 | 06:36 AM
redboost10's Avatar
did you cap off the hose that runs from the t-stat housing to the intake manifold flange? from my experience, that is the only hose that is needed (if running a t-stat) other than the two radiator hoses of course.
Old Oct 13, 2009 | 07:26 AM
hmm i havn't ran mine yet since removing hoses, i only have the 2 rad hoses and the thermo is currently in. I really don't know if i even need it, i heard that just gutting out the mechanical part is better than removing it all together.
Old Oct 13, 2009 | 10:25 AM
locash's Avatar
I run the Fastbrakes single piston drag setup with the lenso's and a small wheel spacer..
Old Oct 13, 2009 | 10:43 AM
Is that a streetable brake system>?
b16b18
Aug 25, 2008 06:53 PM
type B16
Oct 1, 2006 11:17 AM
omar256hxc
19
Dec 20, 2004 12:46 PM
shadowdawn
Oct 6, 2003 10:19 AM
RRRex
Aug 18, 2003 07:09 AM
