don't want my battery to die...quick question
Old Oct 12, 2009 | 10:04 AM
udechukwu's Avatar
Default don't want my battery to die...quick question
just broke my arm last week so my car will be sitting for about 2 months. Is starting her up once a week enough so my battery doesn't die?
Old Oct 12, 2009 | 10:18 AM
inline4's Avatar
Default Re: don't want my battery to die...quick question
depends on how long you let the car run.
Old Oct 12, 2009 | 10:23 AM
93egSLEEPER's Avatar
should be fine. let it warm up so the thermostat opens and rev it up and down a bit (not to rev limiter) just to keep everything well lubed and get the amps up. also you could throw a trickle charger on it for a couple hours a week and it will be fine.
Old Oct 12, 2009 | 10:26 AM
udechukwu's Avatar
sounds good. thanks
Old Oct 12, 2009 | 10:29 AM
gwl's Avatar
gwl
Two months you should be fine not unless the battery is old. Be sure the top of the battery is free from sulfide junk. I have a 65 Chevelle with a 1 and half year old battery that I rarely start and it cranks right up when I start it.
Old Oct 12, 2009 | 10:53 AM
Simkin314's Avatar
Agreed. If your car doesn't start after only a couple months of sitting... your battery probably isn't very good in the first place. On the other hand, I would start it every 2 weeks and let the engine run for a few minutes (~5minutes) to get all fluids circulated and hoses/tubes primed.
Old Oct 12, 2009 | 11:17 AM
udechukwu's Avatar
baterry is 6 months old so i guess i dont need to worry about it dying at all. thanks again
specbb6
Honda Civic (2006 - 2015)
Jun 24, 2012 03:07 PM
rawsx
Mar 10, 2008 10:41 AM
speedracer33
May 2, 2005 08:57 AM
liljohnson
Jul 30, 2004 10:27 PM
GsR HtCh
Mar 2, 2004 08:12 AM
