Need help with complex VTEC activation issue!
Hi folks,
I could really use some help on this one. I am stumped.
Vehicle is a 4g civic with a 1997 JDM type-r(b18c) motor. ECU is a P28 Hondata set-up. The problem we are having is that we cannot get the Hondata ECU to send the +12v VTEC activation signal.
What we know:
- JDM motor does not have an oil pressure switch. Wire from the ECU that would normally go to the switch is firmly grounded.
- If we substitute the stock JDM ITR ecu, VTEC engages normally. This would seem to confirm that the ECT switch and VTEC solenoid are working properly.
- The Hondata ECU works fine if it is used in another (USDM) car. This seems to indicate that there is a vehicle wiring issue, we just cannot determine what. There was a lot of customer wiring done in the engine / chassis harness so it is a possibility.
- We have tried anoher chipped p28 (Skunk2) ECU and it behaves the same way as the hondata. It won't engage vtec in this car, but works in other US-market integras.
- We have intermittently gotten a CEL code of 21 - VTEC spool.
Any and all thoughts would be appreciated.
-Phillip
[Modified by ITR_Hybrid, 11:49 AM 8/29/2002]
What we know:
-Phillip
maybe you have to try something diffrent ECU P28 isnt for that motor your ecu is for D16z you need to get a P62 A11 that should work much better
[Modified by Majuniors_no_vtecfu, 5:08 PM 8/29/2002]
[Modified by Majuniors_no_vtecfu, 6:12 PM 8/29/2002]
you have the wrong ECU P28 isnt for that motor your ecu is for D16z you need to get a P62 A11 that should work much better
go post wrong info somewhere else
i never said it couldnt work on dohc ....i just said try another ecu it seems like he cant get the p28 too work so try something diffrent
does he have a monster tach? check that...sometimes steals the signal from distributor or signal is not strong enough!!
From: Toronto, Canada currently residing in ATL, GA, USA
Are you having a problem with vtec engaging??????? I might've missed that if you stated it but if you are running a JDM motor then you have to substitute the JDM Vtec solenoid for a USDM one that will have wires not tapped off. Your JDM ECU works vtec because it is set up not to look for oil pressure to engage it.
If you are running a P28 then find a vtec solenoid of any b-series motor. (There was a debate about if the SOHN vtec solenoid would work but I don't know if they can or not, I just happen to have a spae solenoid when we swapped a 98 ITR motor in EH).
Keep us posted.
[Modified by Apex i ITR, 11:05 AM 8/29/2002]
Keep us posted.
euclid
Feb 21, 2004 01:02 PM
Backmarker
Aug 30, 2002 09:22 AM
