HELP!!!! civic not starting
ok the civic was running prefectly fine. then i parked it and tried to start it. is cranking over but not starting. checked the fuel its getting fuel. check all grounds its all good. have a feeling it might not be getting spark but i dont understand it goes from fine to ima be a dick and not start lol. any input would help out thanks guys
Check for spark and go from there. If you don't have spark, check the coil and igniter unit and whether the timing belt snapped.
If you have bright white spark, check the mechanical timing.
Any CEL codes?
Any CEL codes?
was just in the same position... you need a distributor!!! your dizzy has both internal ignitor and coil, and why pay for one of them when you can spend 30 bucks more and get a lifetime warranty at autozone on the whole thing?? mine broke down a good hr away from home spent 100 bucks on a dizzy spent 5 mins to bolt it up and she cranked right over!!! btw you wont get a code either.. good luck!!!
headrec*
Apr 4, 2013 08:28 PM
scotty.b16a1
Jan 2, 2013 04:54 AM
billllll23integra
Apr 6, 2008 11:08 AM
