95 DX: Replaced axle oil seal, still leaking?
Old Oct 11, 2009 | 10:05 AM
tamadrumr88's Avatar
Default 95 DX: Replaced axle oil seal, still leaking?
#32 in the pic
Had a minor leak, replaced the seal for about $12 from the dealer. Still leaks, maybe not as much but it still leaks from the passenger side seal where the axle enters the bell housing. Any ideas? The manual doesn't call for any special sealant or procedure aside from driving the seal in using a large socket. Pulled the axle again this morning, tried tapping it again to get it to sit differently/correctly so we'll find out soon if that worked or not...
It's not leaking around the outer edge, however, it's leaking from the center/inside where the axle goes through. Any ideas? The car is a
95 DX Auto
Old Oct 12, 2009 | 09:15 AM
Default Re: 95 DX: Replaced axle oil seal, still leaking?
bump
Old Oct 12, 2009 | 09:25 AM
gwl's Avatar
gwl
That's really odd. The only time that I had a leak like that with a new seal, the spring in the seal had came off. Are you sure that have the seal inserted in the right direction? The spring side of the seal(exposed) must be installed toward the inside of the transmission.
Old Oct 12, 2009 | 10:27 AM
Yes, the spring is facing inwards. As far as I know (and hope), the spring is still attached on the backside of the seal. I'd really hate to pull it a third or fourth time
Old Oct 12, 2009 | 10:40 AM
gwl's Avatar
gwl
Its a long shot, but maybe the leak can be cause by the axle. On old motors, the crank at the end of harmonic balancer where it seals at the timing cover are sometimes sleeved with brass. The cranks are worn down to a point that it will leak even with a new seal.
relative4
Jan 18, 2018 06:56 PM
GuiGJ
Jul 28, 2009 09:14 AM
JDM_SOHC
19
Dec 23, 2007 03:21 PM
dewoine
Apr 29, 2006 11:31 AM
boardrider
Mar 10, 2006 10:16 AM
