removing altnator dohc zc
Old Oct 11, 2009 | 08:15 AM
jbrokos307's Avatar
Default removing altnator dohc zc
ok i used search and failed i have it all unbolted un pluged now i puzzled how to get it out i have a dohc zc in a 89 si do i have to loosein the motor mount and remove the drive shaft
Old Oct 11, 2009 | 08:30 AM
beansandrice's Avatar
Default Re: removing altnator dohc zc
No. Once you have it removed you have to manuever it around untill it comes out. You dont have to remove any thing.
Old Oct 11, 2009 | 10:15 AM
thisiskev's Avatar
yea you should be able to get it out without having to undo anything else. you just have to maneuver it the right way.
Old Oct 11, 2009 | 11:36 AM
sde780's Avatar
Did you take the long bolt out. I had to turn my wheels a certain way so it would drop out
Old Oct 11, 2009 | 01:39 PM
crxjarred's Avatar
i had the same problem striped out one of my alt bolts and i couldnt get it out so i just put a longer bolt in it and a nut...
Old Oct 11, 2009 | 04:49 PM
efzchb's Avatar
you have to remove the bottom bracket that the long bolt goes through and it slides right out between the engine and axle
Old Oct 11, 2009 | 04:58 PM
jbrokos307's Avatar
i got it another way is pull master cylnder and push it out the way and slides right out no problems thanks guys
LowAndSlowEF
Jan 13, 2012 07:58 AM
freddysEF
19
Jan 26, 2008 06:58 AM
89ZCTeg
Jul 13, 2007 11:23 AM
BuddhasGift2You
Nov 10, 2005 11:57 PM
Blindstuff
16
May 19, 2005 08:26 PM
