rear disc brakes
O.k. so i got the crx si rear disc brakes.. i was wondering will my stock civic si e-brakes lines work with the crx si rear disc brakes or do i still have to get the 90-93 integra e-brake lines? Thanks
The integra brake cables are going to be longer.. There are 3 different e brake cables crx drum and disc rears and integra and all DC DA EF EG Ek these are little longer... Crx disc cables are to short to fit civics so if you had integra cables on crs then they would be to long..
uhm can someone explain this a little better...
so I bought the DA e-brake cables for my rear disc conversion(this is for my ef hatch) do i have to do any modifications or they just bolt up right away and just adjust it?
Your correct, No mods required...
Your DA e-brake cables will work perfectly..
Just a side note: Have you replaced the trailing arm bushings?... Because the original ones have the tendency to be shot when most people get the swap from the donor car..
*Boostwerks*
Apr 26, 2007 10:25 AM
