Question on removing ac compressor
I want to remove my ac compressor but I was wondering if I can still drive without having ac belt on or do I need like a dummy belt. I'm gonna get my compressor refurbished but I still need to drive around in the mean time. My car is a 89 dx sedan if it matters.thanks
Yeah it happened to me... the harmonics will not be absorbed anymore by the A/C Compressor and they will all go to your cam bearings. Next thing you know your crank will snap in 3 pieces and you can say bye bye to your push rods.
let all the freon out 1st, then take the 2 10mm bolts off the lines, use a shallow end 12 or 14(i think 14)mm socket to take off the 4 bolts that are holding it onto the plate. this all should be done after the belt is taken off
I am pretty positive that the head of the 8mm bolts holding on the A/C Compressor is a 12mm hex head.
