blowing out oil from valve cover
replaced gasket wont stay set right keep blowing it out cause???? possible pcv malfunction not enough torque on valve cover studs and who has a better gasket then the shitty fel-pro perma dry seal cause they fit like ****?????
so the gasket actually keeps coming out of the groove in the valve cover and allowing oil to leak out?
I doubt it's the torque, you only need to tighten those to 7 ft/lbs.
I've never used fel-pro gaskets, I've always used oem Honda gaskets.
Even though it's considered a dry-apply gasket, I typically use something like Permatex Hi-Tack spray adhesive to position the gasket; after thoroughly drying what I want it to stick to.
Fel-pro has been around for years and has never given me any issues. Just make sure that everything's absolutely clean when you assemble everything.
P
yeah im going to order a oem one friday when i get paid and just silicone and silicone the fel pro pos in place to get me back to sd from mo
Yuta
Dec 12, 2015 05:27 PM
Shaguar47
May 28, 2007 08:47 AM
iLovPhoKing
Jan 2, 2006 08:07 PM
