JDM B18C misses and lacks power
Old Aug 29, 2002 | 05:20 AM
JDMB18CEH3's Avatar
Default JDM B18C misses and lacks power
Just got a JDM B18C put in my 1993 Civic Si
-engine has 50,000 miles/82,000km
-used P72 ECU and modified my stock Si harness
-no CEL comes on
-car ran well the first few days but could not tell for sure if the VTEC was activating
(ie no great change in performance compared to my buddies 99 Si(R) (B16A2)
Now the car sometimes misses at idle and while driving and lacks power.
-changed the dist. cap and will replace rotor and plug wires as soon as the dealer gets them in.
-fuel filter is nearly new
Any ideas anyone?
rotor/cap/plug wires?
timing?
fuel/injectors?
What is the optimal octane for JDM engines?
Old Aug 29, 2002 | 06:47 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: JDM B18C misses and lacks power (hot salsa)
They can run on 91 octane (I tired it out because i couldn't find anything else and I was about to run out of gas.
Old Aug 29, 2002 | 12:16 PM
JDMB18CEH3's Avatar
Default Re: JDM B18C misses and lacks power (Apex i ITR)
anybody else?
Old Aug 29, 2002 | 12:22 PM
B18C-Hatch's Avatar
New User
i am having the same problem with my B18C, check if the secondary is opening up, the little metal 'pole' will actually move when it engages under the vacuum thingy, here is a link with a pic.
https://honda-tech.com/zerothread?id=265558
Old Aug 30, 2002 | 11:15 AM
JDMB18CEH3's Avatar
Default Re: JDM B18C misses and lacks power (B18C-Hatch)
ttt
Old Aug 30, 2002 | 01:18 PM
madman604's Avatar
are you using the JDM ECU as well? the civic one works, but its not perfect. Use the JDM unit and be sure to hook up the knock sensor and AIB sensor.
The Civic ECU gave no CEL either, but ran really rich and sluggish.
After i changed to the JDM ECU it ran Beautifully.now i can feel the Vtec engaging.
Old Sep 3, 2002 | 12:51 PM
JDMB18CEH3's Avatar
Default Re: JDM B18C misses and lacks power (Turbo E)
Changed the plug wires with NGK blues. Car now runs perfect. Thanks
wtsapexipowerfc
Sep 4, 2016 09:53 PM
Yasutaka
Mar 13, 2007 01:35 PM
.Hookedonhatch.
Jul 20, 2004 10:20 PM
spender1326
Mar 22, 2004 03:42 PM
