GSR Type R conversion
question about the ecu. If i were to replace the engine, trani, and ecu with the B18C5 Type R engine. would the existing loom still work? are all of the connections the same? I don't remember if the type r ecu is obd2 or not?
any help would be great!
thanks
Steve
[Modified by teger, 12:44 PM 8/29/2002]
thanks
Steve
here goes the flames...may god have mercy on your soul...
True wont be a Type-R but still..its the biggest form of flattery..
...good luck with the conversion man
its not even that great of a motor. i would just build up the motor you have.
seriously man, you could run circles around an R with the money you'll spend on an R engine.
go with a Turbo setup that's dyno tuned and you'll probably be spending the same amount for more power. Heck, even going NA (pistons, more displacement, cams, tuning) right there you'd be set.
You can do as much as you like but it will never truly be a type r. Build up the motor or go turbo.
Get over yourself and your own car.
[Modified by Migs, 6:44 AM 8/30/2002]
I respect what you want to do to YOUR own car but, THAT'S A FRICKIN $5K MOTOR! You can have a fully built or close to a fully fully built N/A Geezer with them kinda feds. Also, from experience I tried to hook up a 2000 ITR computer into my car and it kept shutting off after I started it. Eventually, it wouldn't even start after like the 3rd try. I guess it has to do with that anti-theft thingy.
Maybe people want the ITR motor soooo bad because then they can say, "Yes it's a real B18C-R orrrr B18C5 to their friends. Also because "Oh my gosh it's the infamous Integra Type-R engine!" Mmm...Mmmmkay?
Basically the main difference in times between an ITR and a GS-R isn't the car itself, it's the driver (Drag Race of course, cause everyone knows the R's suspension is killer!) So if you're Steph Papadaklis Jr. and you can drive, then you can take on the average 'Mr. Bought My Type-R Because Everyone Knows They're Fast And I Can Intimidate People.'
It's not how ya stand by your car, it's how you race your car. You better learn that...
The only thing I would really want from an R is the suspension. Thinking about getting that pretty soon anyways. Also the front lip. Other than that, everything else doesn't tickle my fancy too too much.
Like some others have said, build what you have. Spend around the same amount, and have around 25-30 more whp when you're done. If you go boost, the margin will be even greater!
Jason-
who loves his car, but realizes it's just an Integra
[Modified by Jason Franza, 5:48 AM 8/30/2002]
Jason-
why? so you can say you have an extra lug? whoop-tee-do... you can get stiffer and better struts by going aftermarket.....
The price of a ITR motor isn't that bad as some of you make it seem.
Yeah it's 5k.......and yeah 5k can give you alot of mods. But don't forget the cost of selling the old gsr motor. You can get around 3k for it. SO 2k is the overhead.
So you get the ITR motor, LSD tranny, ITR mounts, jdm 4-1 header (if a jdm swap) *if your deal includes* And a practically stock motor that will be reliable and smog legal. You don't have to worry much about tuning and tweaking to get more power. It's alot less headache.
I've spent the money on my gsr engine and ended up with like 160whp. I did the *so frowned upon here* swap and put 174whp with only exhaust. And 185 with intake and an ecu drop in *mugen for all the disbelievers*.
Yeah i could have gone turbo, jrsc, or whatever. But maybe i'm not after insane power gains, but a simply fast, reliable street driven that isn't a monster, but well above what i had.
Oh yeah, the 5 lug conv was worth it too. The brakes just kick ****.
All in all, I say go with what YOU want. Set a goal and see your options to get there and pick the one that makes YOU happy. Not sure about everyone else here, but i'll be happy for you
Akira-R. Thanks for your positive input. He understands exactly what i'm trying to achieve. One thing about the type r motor, is it's reliability as a stock motor. I am not trying to be a Type R. If I could afford one, I would buy one.
I cant tell from your tone but YOU my friend are what makes ITR owners jerks. Straight out.
Not all R ownders are jerks man...i just happen to drive a Type-R and i love it but i dont hate on other cars, im actually a huge fan of all cars as we all should be
And teger...like i said before man good luck with w/e YOUR project is going to be..to each his own ...
For the right amount of money, any car can be built to out perform other cars out there.
I have Mucho respect for the R's, but trying to be one is a different story. Just build and enjoy what you got and go from there...
its called better brakes dummy
And its called big brake conversion Idiot. such as fast brakes, AEM, WIldwood and so-on...
[Modified by VoLTRoNx916, 1:50 PM 8/30/2002]
ITR motor + Trany = $6,000
Free GS-R motor + Turbo + Header + Cat + Intake + lightweight flywheel + lower gearing + Cams + modified edu + dyno tuning = less than $6000 and would beat the snot out of most corvettes.
[Modified by jond, 4:55 PM 8/30/2002]
Type R = buy it, enjoy it, appreciate what honda created...don't fuc with it.
all other integras= build it up and smoke some R's for breakfast.....just my opinion
Build your geezer motor....it's more cost effective.
