how long have you gone without changing oil?
Old Aug 29, 2002 | 03:05 AM
ITR#JohnBasedow's Avatar
Default how long have you gone without changing oil?
3300, so i guess that would be 300 over. I hope that isn't much.
Old Aug 29, 2002 | 08:36 AM
mingchi96
Guest
Posts: n/a
Default Re: how long have you gone without changing oil? (ITR0863)
my friend wit ha vx hatchback hasnt changed his for like 9000 miles.. when he finally did... omg, did the oil stink. That car also has 200000+ miles on it too.. how?? i do not know.
Old Aug 29, 2002 | 08:40 AM
Dave-ROR's Avatar
about 50K between changes on my B18C.
Old Aug 29, 2002 | 08:41 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: how long have you gone without changing oil? (SoFreshAndSoCleanClean)
1.5 years...
... on the Scout
Old Aug 29, 2002 | 08:43 AM
TsunamiZC's Avatar
Default Re: how long have you gone without changing oil? (Splat)
the longest i went was 6000 miles on the G1 ...thats when the old D16a1 was on its last legs , burning oil like a biatch, it wasnt worth changing it ...it burnt it away to quick
Old Aug 29, 2002 | 08:44 AM
sackdz's Avatar
Default Re: how long have you gone without changing oil? (tsunami_zc)
I haven't changed oil in probably 15k, with about 8 or 9 track days/autox's in that span....
I only add
[e]-I have changed the filter a few times though
[Modified by sackdz, 12:45 PM 8/29/2002]
Old Aug 29, 2002 | 08:48 AM
VTECPWR's Avatar
Default Re: how long have you gone without changing oil? (sackdz)
My friend was looking at a truck, the guy claimed that he had not changed the oil in 100,000 miles, he just added oil when necessary. But it was ok because he used Mobile1.
I also knew a guy that had an Integra that had not changed his oil in 30,000 miles, felt it was ok because he used Mobile1 and he did not burn any oil. The worst part was his mechanic agreed with him.
Old Aug 29, 2002 | 08:49 AM
TsunamiZC's Avatar
I only add
and why havent you changed your oil
Old Aug 29, 2002 | 08:51 AM
norice's Avatar
The 3k oil change must be one of the greatest marketing successes of the last 20 years. Most car manuals now recommend 7.5K miles. My friends in Europe change their oil every 10k miles.
Newer Mercedes have an oil contamination sensor and drive their (US) owners mad by not recommending an oil change until 20k+ miles.
If you use synthetic, changing every 10-15k miles is enough. (Unless you are a track *****.)
Old Aug 29, 2002 | 08:53 AM
MPH's Avatar
MPH
New User
I change mine around 4000 miles on the R. When I had my CRX I would change it at 5000 miles. That car had 223,000 miles on it and was still running strong when I wrecked it.
Old Aug 29, 2002 | 09:31 AM
qbsi's Avatar
Default Re: how long have you gone without changing oil? (norice)
i have gone without a change for like 10k miles.
it was black as ****.
now days, i change it about every 5000 miles or so. mobile 1 synthetic.
my brother knows someone in mobile (research and development team), he says that you really dont need to change it every 3000 miles or so. just change it around 5000 or 6000 miles because cars these days are much more efficient.
he has a new corvette and changes his oil every 7000 miles or so.
plus he recycles those oil and puts it in his motocycle.
the reason why most mechanics tell you to change every 3000 is another way of making money. i agree somewhat on that.
Old Aug 29, 2002 | 09:38 AM
00R101's Avatar
Default Re: how long have you gone without changing oil? (qbsi)
The reality is that once the car has broken in it can not possibly hurt to change it every 3K. Acura recommends every 7.5K for normal use and half that for severe use. I consider anyone doing regular track or autox days as severe use so every 3.75K sounds right to me. It's cheap insurance.
The reality is also that most new engines will probably run 100k without an oil change and anything more than that really only helps extend life beyond 100k. Change more often and you get extended life.
Also if you don't change the filter then changing the oil is pretty much a waste of time.
Old Aug 29, 2002 | 09:43 AM
Ricky Rojales's Avatar
...until my oil pressure started dropping and VTEC would engage and disengage while flooring it...
Worn oil rings suck!
Old Aug 29, 2002 | 09:47 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: how long have you gone without changing oil? (Suicidal)
when vtec stops working....
Old Aug 29, 2002 | 10:03 AM
yoshi234's Avatar
I shoot brides
~7500 miles w/ NeoSynthetic oil...'l00ked' g00t as the day I put it in- nice golden color
Old Aug 29, 2002 | 10:06 AM
Anderson's Avatar
Default Re: how long have you gone without changing oil? (yoshi234)
never
Old Aug 29, 2002 | 10:33 AM
ITR 2K's Avatar
If you use synthetic then 300 miles over is not that much. I always change mine every 2500 miles, with Mobile 1 Supersyn 5w-30.
Old Aug 29, 2002 | 10:37 AM
SoCal ITR's Avatar
Default Re: how long have you gone without changing oil? (ITR 2K)
I usually change it every 3k, but I went 4k once.
Old Aug 29, 2002 | 10:40 AM
Black R's Avatar
25 Year Member
.....you mean you're supposed to change the oil? How do I get it out of that cap?
Old Aug 29, 2002 | 10:41 AM
coquinn's Avatar
Default Re: how long have you gone without changing oil? (Black R)
... you mean you're supposed to change the oil? How do I get it out of that cap?
Don't forget (when you figure out how to get it out of the cap) that you are supposed to fill it all the way back up to the top.
Old Aug 29, 2002 | 10:55 AM
schumiR's Avatar
Excellent post and the truth. BMW's have similar sensors as the Benz's and after having two BMWs the sensor went off at around 12,000 -14,000 miles. Oil companies are making a killing because quite a few people change their oil every 3000 miles. With today's oil it's just not necessary unless you're tracking, adhear to the severe maintenance schedule or just want to waste your money. Follow the owners manual.
[Modified by schumiR, 11:56 AM 8/29/2002]
Old Aug 29, 2002 | 11:04 AM
Hooch'n's Avatar
Default Re: how long have you gone without changing oil? (schumiR)
Apply when needed!
Old Aug 29, 2002 | 11:06 AM
Johnny Tran's Avatar
Default Re: how long have you gone without changing oil? (8400-RPM)
crx = 200,000 miles. i will change it when it siezes and i must replace all fl00ids.
Old Aug 29, 2002 | 11:16 AM
Eric R's Avatar
Default Re: how long have you gone without changing oil? (Johnny Tran)
I go by what the owner's manual says. I rely more on what Mr. Honda says than what the lube centers say. That every 3K miles oil change is just unnescessary and a way to spend more money in maintnance. Also, is to increase the oil and filters sales up so the marketing chain keeps happy.
Old Aug 29, 2002 | 11:28 AM
Splat's Avatar
j00 mean the "710" cap?
