del sol custom fog light mounting/wiring ?'s
Old Oct 9, 2009 | 09:56 PM
Zector's Avatar
Default del sol custom fog light mounting/wiring ?'s
hey all
so i just traded a rear lip for some brand new eg fog lights with all the wiring.... my question is if anyone knows how to wire it up or if there are any install guide somewhere. i know its been done before but cant find anything but pictures.
or is it the same as any eg civic? kinda wanted to wire it to the aux light switch and delete those ugly aux lights in the process lol.
any help would be greatly appreciated!
thanks in advance!
Old Oct 9, 2009 | 10:51 PM
thumper64's Avatar
Default Re: del sol custom fog light mounting/wiring ?'s
Don't hack up the factory wiring. Just wire the fogs to another switch mounted on a removable panel on the dash, triggered by a relay. You'll have 4 wires going to the relay. You'll have switch, ground, hot and load. Switch you have a 12V source running to with a switch inbetween. Ground is...grounded. Hot is 12V constant. Load goes to the lights. The diagram will look like a gate crossing over a coil. One end of the coil is ground the other is switch. The gate, one wire is hot and the other is load.
Double check all of that, it IS 2AM here...
Old Oct 9, 2009 | 11:10 PM
Zector's Avatar
sweet thanks man so its pretty much all custom then the guy did include the eg fog light switch so i guess ill see what i can do with that... thanks!!
crazyhorse2011
Aug 3, 2016 05:52 AM
06Accord5SPD
Feb 22, 2016 03:10 PM
gk19
Mar 19, 2010 09:04 AM
sileighty_911
Audio / Security / Video
Jun 19, 2007 01:38 PM
popeface
Apr 6, 2006 03:20 PM
