can i tell before tearing down if it's a cylinder wall or head gasket?
Old Oct 9, 2009 | 08:55 PM
chatman_55's Avatar
Default can i tell before tearing down if it's a cylinder wall or head gasket?
I've heard from certain unreliable mechanics that there is no way to tell if my issue is a cracked cylinder wall or a blown head gasket without tearing the engine apart first, i just want to be sure. so is there a way to tell? Want to know so im fully prepared for whichever it is once i get everything pulled apart.
Old Oct 9, 2009 | 09:05 PM
Adam_b16a's Avatar
Default Re: can i tell before tearing down if it's a cylinder wall or head gasket?
you have to pull everything apart anyways right? Whats the difference if its a headgasket or cracked sleeve if you just have to tear everything down anyways.
Old Oct 9, 2009 | 09:08 PM
gstrudler's Avatar
Seems unlikely that you'd crack a cylinder wall before blowing the headgasket unless there was some serious detonation happening.
Old Oct 9, 2009 | 09:13 PM
chatman_55's Avatar
The reason i would like to know which it is before hand is so i can have the part on hand when i tear it down as it's my only vehicle and can't have it down for too long.
Old Oct 9, 2009 | 09:16 PM
Adam_b16a's Avatar
well your going to need a new headgasket anyways, because if its a cracked sleeve then your going to have to tear the motor apart anyways. And if its a headgasket, then your going to have to tear it apart anyways lol
Old Oct 9, 2009 | 09:48 PM
BigBlock22's Avatar
the reason they told you that was for the fact that both problems have similar symptoms. you have to open the engine up if you want to know for certain where the trouble is coming from.
Old Oct 10, 2009 | 01:14 AM
DDTECH's Avatar
leakdown is ur best bet..
remove rad cap, headers, and manifold, and put it in.. try to hear leaking, if u see bubbles thats not cool.
Old Oct 10, 2009 | 06:27 AM
projectTeG's Avatar
pull the head and move the pistons down to middle bore, most of the breaks in sleeves come from the squinch area. you can see the cracks mostly. the have the head inspected.
you can read a headgasket from the wear on it
Old Oct 10, 2009 | 09:30 PM
PyroProblem's Avatar
Borescope down the sparkplug hole...
Civic082382
Honda Civic (2001 - 2005)
Sep 18, 2013 03:08 PM
blackmfoggie
Jun 9, 2007 04:49 PM
italianaccord
Jan 23, 2006 10:57 PM
ItzTw
Feb 24, 2005 04:24 PM
