loss of power will cruising
I have a 94 VX with stock motor. When I'm just cruising down the road 40, 50, 60 whatever mph it seems like the fuel pump cuts out. When I press down on the throttle it takes a second and then power comes back. It only happens when I'm cruising I dont have problems if I hold the peddle down a little bit to slowly accelerate. Could it be the tps?
actually it is the tps. i unplugged it and its runs fine now just idles high but it fixed the other problem so im off to the junkyard to get a new one thanks tho
manual, no codes, i did calibrate it, i dont know when the plugs and what not were changed the timing is fine
i think its this tps cuz it doesnt idle right now but it did with the old one
netfreak
Aug 29, 2018 04:57 PM
EF9Infantry
Feb 4, 2012 03:36 PM
Ehop
11
Feb 11, 2008 10:09 AM
ef8b16a1
Feb 15, 2006 05:01 PM
