mini me swap. a6 block with z6 head
Old Oct 9, 2009 | 07:09 PM
kusyurdaddy's Avatar
Default mini me swap. a6 block with z6 head
this is old but cant find any info. just did a mini me swap. got the head on but i cant use the obd1 dist. from an z6 will not start. but if i use the obdo dist then the car can start. i dont want the dist to be holding by 1 or 2 bolts. i like the clean look with the right dist. cant any one help ?
Old Oct 9, 2009 | 07:34 PM
BiG ChOr!Zo's Avatar
Default Re: mini me swap. a6 block with z6 head
http://crx.honda-perf.org/articles/z6swap/z6swap.html
Old Oct 9, 2009 | 07:45 PM
D16SiHatch's Avatar
that writeup says to keep the obd0 dizzy and run an rpm activated switch. don't do that.
do it the right way and convert to obd1 and run a p28.
http://rywire.com/store/8891-crxcivi...0fc29428615f7e
Old Oct 9, 2009 | 09:01 PM
Tyson's Avatar
why not? converting to OBD1 is a lot more expensive than a RPM switch.
Old Oct 9, 2009 | 10:37 PM
D16SiHatch's Avatar
well sure it is. but generally doing things the right way is by definition more expensive.
seriously though? if i expected anyone to condone use of an rpm switch i would not of expected it from someone like yourself.. i don't know why i'm even saying it cause i feel like you must know.. but by running vtec to a switch and retaining the pm6 ecu you're essentially just making a fancy noise machine. without the proper vtec fuel maps engaging the solenoid is pointless.
Old Oct 10, 2009 | 08:48 AM
Tyson's Avatar
no, i just expect you to qualify blunt statements. thats why.
Old Oct 10, 2009 | 08:53 AM
fireant's Avatar
There is a rom for a chipped PM6 that has dual fuel maps and uses the AC relay as the vtec switch.
Old Oct 10, 2009 | 08:58 AM
Tyson's Avatar
would a PS9 work?
Old Oct 10, 2009 | 09:12 AM
Tyson's Avatar
yay for search.
http://www.xenocron.com/te.php?page=TEvtec
HiProfile
Jul 11, 2007 12:13 PM
theonecalledtodd
Mar 20, 2007 05:48 PM
vegaskurt
May 14, 2005 10:17 PM
mengy007
Jan 25, 2005 02:46 PM
hatchback_al
Sep 27, 2004 11:31 AM
