Head gasket n studs??
Which head gasket and head studs would you guys recomend for a 300hp boosted stock b16? I was thinking of a thicker gasket to lower compression but i don't know much about those type gaskets? any info would be great,thanks
i have always had luck with cometic and arp. but the last few 35 psi passes, my luck may have ran out.
on the way is the golden eagle head gasket and golden eagle studs.
if i get a cosmetic hg, which bore size would i want to get for my app? 82mm, 84mm??? would that lower comp any? just a little confused on the bore choices with a cosmetic gasket and which one i'd want
as for a thicker or thinner headgasket, that is what can bump you compression up or down a couple of points.
IMO i would use OEM if you have stock pistons + ARP headstuds and call it a day. i just bought an OEM headgasket for my gsr and ARP's that ill be putting on before it gets boosted.
just my .02 cents....
bungdogjb
Engine Machining & Assembly
Nov 21, 2015 08:06 PM
roycivic92
Apr 7, 2010 10:07 AM
