gsr vs itr crankshaft
Old Oct 9, 2009 | 05:28 PM
ee8_pt's Avatar
Default gsr vs itr crankshaft
hi
what is the differences between itr and gsr crankshaft?
itr crankshaft is better?
thanks
Old Oct 9, 2009 | 05:56 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: gsr vs itr crankshaft
ITR crankshaft is slightly heavier because of larger counter balancing weights. Better? Better for what?
Old Oct 9, 2009 | 07:52 PM
slo blue's Avatar
the extra weight adds more torque, not much though
Old Oct 9, 2009 | 08:22 PM
racebum's Avatar
i really want to hear the this be explained.
please, tell us how
Old Oct 9, 2009 | 08:27 PM
mar778c's Avatar
Community Builder
Community Influencer
^^X2
Old Oct 9, 2009 | 08:36 PM
DDTECH's Avatar
inertia
Old Oct 9, 2009 | 08:42 PM
mar778c's Avatar
Community Builder
Nope. A reduction in inertia can increase torque.
Old Oct 9, 2009 | 08:43 PM
DDTECH's Avatar
Originally Posted by mar778c
Nope.
oh well, i tried to help a brother out lol.
More weight does not add torque btw.
Old Oct 9, 2009 | 08:45 PM
mar778c's Avatar
Community Builder
Lol,
I love you dude.
Old Oct 9, 2009 | 08:46 PM
steveo135's Avatar
ITR crank is balanced to a higher rpm than the gsr for higher revving..
i guess it depends on your goals to say whether or not its better
Old Oct 9, 2009 | 08:50 PM
DDTECH's Avatar
neither is really better then the other.. they are both good cranks.. doesn't matter which u use.
Old Oct 9, 2009 | 11:10 PM
all-mtr-teg's Avatar
Please explain how an ITR crank is balanced to a higher rpm vs. a GSR?
What RPM is a stock GSR crank good to?
Old Oct 10, 2009 | 10:55 AM
slo blue's Avatar
every part from a type r makes more torque
Old Oct 10, 2009 | 11:06 AM
BlakeJ53's Avatar
If you want to make more tourqe use a LS crank in your gsr/type r block. A gsr crank has a 87mm stroke and a LS crank has 89mm stroke. All B series cranks will take high rpms. Its is the stock rods and rod bolts that cant take the super high RPMS.
Old Oct 10, 2009 | 11:45 AM
steveo135's Avatar
ok let me reword that...
The ITR crank is balanced to reduce vibration in higher rpm.. I've read it reduces vibration up to 20% i dont know what exactly that is compared to (gsr or ls)
as far as what rpm a gsr crank is good to.. i have no idea i guess you'd have to rev it till you break the crank or everything vibrates apart.. my guess is that you'd have problems with other parts handling the revs before the crank would have a problem...
i dont think you really cared to hear that answer though.. you probably just didnt understand what i was saying and were calling
Old Oct 10, 2009 | 12:33 PM
slowd16y8's Avatar
^^in that case why not buy a gsr crank for less than a type r and send it to a machine shop to be balanced and lightened?
Old Oct 10, 2009 | 02:02 PM
steveo135's Avatar
it'll probably end up costing a little more because im sure the balancing costs more than the difference between the two cranks... but it'l probably be a little better balanced
Old Oct 10, 2009 | 02:44 PM
SergEK's Avatar
Years ago when I was a noob I called JUN USA to ask about their motor building services
When I asked them if they knife edged cranks they said NO NO NO NO
They either kept stock weight or added a little to help with vibration/balancing at 10K+rpm
While knife edging will make the rotating assembly lighter and unlock a few ponies the trade off is the counter weights cannot counter the changes of direction as well
I would assumer the bearings will take on more load as revs rise and the counterweights get lightened too much
Maybe JUN was wrong, but I was inclined to think they knew what they were doing for longevity
A drag motor isnt going to see the extended high rpm sessions a road race motor will and JUN built more road race motors than they ever did drag (still built a 8 sec SR20 in 90's) so for street use I would keep the weights/add weight to compensate high rpm use and help the motor last longer even if it didnt unlock 2-5whp...
Of course light weight pistons/rods help offset the forces at 10-11K but you get the point
Old Oct 10, 2009 | 03:52 PM
DonF's Avatar
Some days i just enjoy myself on here.
Bad information is worse than no information.
Old Oct 10, 2009 | 08:43 PM
steveo135's Avatar
100% agree
Old Oct 10, 2009 | 08:47 PM
PyroProblem's Avatar
Engines 95?
Old Oct 11, 2009 | 06:08 AM
ee8_pt's Avatar
thank you guys
so gsr crankshaft if was balanced can make more power than itr crankshaft?
Old Oct 11, 2009 | 06:22 AM
mar778c's Avatar
Community Builder
^^^there is an excellent chance this is possible.
92integraVTECgsr
Feb 16, 2006 08:47 PM
vtecmonster001
Feb 20, 2005 03:53 PM
vtecmonster001
Feb 14, 2005 04:34 AM
lke2drvgsr
Feb 9, 2004 06:58 PM
austrian type-R
May 20, 2003 11:24 AM
