Question About ITR and CTR Cams!!!
Old Aug 29, 2002 | 12:38 AM
PROJECThX's Avatar
Default Question About ITR and CTR Cams!!!
I know that the 2000-2001 Intake cams are the same as the CTR cams but the 98 itr cams are different. Is there a difference with the JDM 98 itr cams?? Or are they same as the USDM?
Old Aug 29, 2002 | 06:53 PM
PROJECThX's Avatar
Default Re: Question About ITR and CTR Cams!!! (PROJECThX)
ttt
Old Aug 29, 2002 | 06:54 PM
Eric R's Avatar
The word is 'duration'.
Old Aug 29, 2002 | 07:25 PM
skafia's Avatar
25 Year Member
Default Re: Question About ITR and CTR Cams!!! (Tweety R)
Since 00-01 Type R Intake Cames are identical to the CTR cams... would it be worth it for me to change out my 98 ITR cam to a 00/01 or CTR cam?
Old Aug 29, 2002 | 08:18 PM
Dirty GS-R's Avatar
New User
Default Re: Question About ITR and CTR Cams!!! (skafia)
I doubt it would make much difference. Not worth the time and money IMO.
Old Aug 30, 2002 | 09:31 PM
B2FiNiTY's Avatar
Default Re: Question About ITR and CTR Cams!!! (skafia.cw.r)
I would only do it if you had it for cheap. Plus it's just the intake cam. WIth the money spent you can get aftermarket ones.
Old Aug 30, 2002 | 09:43 PM
H-PIMP's Avatar
Default Re: Question About ITR and CTR Cams!!! ([B2]FiNiTY)
I would only swap cams to put in spoon or maybe even Toda spec A's.
Old Aug 30, 2002 | 09:57 PM
GokuSSJ4's Avatar
Default Re: Question About ITR and CTR Cams!!! (H-PIMP)
the differences is only on the intake cam , exhaust cam for 01 ,98 and ctr is the same .
as 01 is not the same (very close ) but not the same off by 1 degree of duration .
ctr has 3 degrees over 98 spec and 1 degree over 01. but most people go with 01 cause is not going to make much of a difference (unless that you are changing them from a B18c1 or b16a ) but the 01 intake cam is cheaper then getting a ctr intake cam ...
[Modified by Spoon1, 6:58 AM 8/31/2002]
Old Aug 31, 2002 | 02:33 AM
ITR 2K's Avatar
I would just go with after market cams. JUN 3's, are a hell of a lot better than CTR's.
A.R
Feb 4, 2010 07:41 PM
B16A JDM EG
Nov 24, 2006 11:39 AM
AllMoToRB18c
Oct 26, 2003 02:33 PM
SMZ GSR
Jul 15, 2002 05:57 PM
R-Adrenaline
Sep 18, 2001 12:06 PM
