B16a2 JDM Rebuild - Opinions?
Does anyone see anything wrong with this build or have any recommendations?
94 b16a2 JDM
-stock 81mm bore
-p30 JDM pistons
-Skunk2 Stage 2 Cams
-Omni Power Valve Spring/Tit Retainers
-Supertech Flat Nitride Coated STD Vavles
-RC 310cc Injectors
-2 layer Headgasket (prob buddy club)
-head milled 0.020 inches
-AEM Tru-Time Adjustable Cam Gears (5 bolt) (degree cams to specs)
-stock P30 IM and TB
-Comptech Header
-ARP Head Studs
-Mfactory LSD
-Chipped p28 tuned on chrome most likely
OEM:
-Rings/Bearings
-Oil Pump, Water Pump, Timing Belt, in/ex gaskets, main seal, valve seals
According to C-Speed calculator looking at about 11.3:1 CP + flat valves
Opinions?
(Yes I know should go bigger than 1.6 but I know this engine's history and I have a budget for the build)
94 b16a2 JDM
-stock 81mm bore
-p30 JDM pistons
-RC 310cc Injectors
-Comptech Header
-ARP Head Studs
-Mfactory LSD
OEM:
-Rings/Bearings
Opinions?
do you have to mill the head to run flat valves? Also about how much more compression do the flat valves give ya? I am thinking about running them in a b17a1
ALLOUT CL55
30
Jun 27, 2010 09:32 AM
.I.Need.Money.
Feb 22, 2007 11:28 AM
